[Official] DVB-T2 USB/PCI-E/PCI TV Tuner Thread
zoneguard
3. Astrometa version 2. Newest purchase below USD$20. Couldn't get it to work under Linux despite kernel support. BDA driver in Windows 8 and TVR app works fairly well. BDA driver means third party PVR software works. For most people who use Windows OS, this is the obvious choice since it is cheapest and has BDA drivers for DVB-T2 and DVB-C support.
Got this to work in Linux using staging driver mm88473 for DVB-t2. I also reused the PCB balun from the small rabbit ears antenna that came with Mygica T230. I gently broke off the 2 rabbit ears and opened up the casing for the antenna to reveal the PCB balun inside. Hooked the balun up to a loop antenna and used it with the Astrometa v2. I will test dvb-c next time.
I think this stick is my preferred choice due to its price point and OS versatility.
LxIxVxE
Senior Mentor
TBS 6281SE DVB-T2/T/C Dual Tuner PCIe Card (direct replacement for the previous 6281)
Abt US$80, only available online
Also hearsay H brand will be releasing a quad tuner PCIe card at a later date~
14563916440_zpsfuffpjmp.jpg~original
14563916441_zpsby7tvxtl.jpg~original
Kiwi8
Deluxe Member
I notice this 6281SE uses the screw-type coaxial socket instead of the plug-type socket eh? :o
Other than this, any noticeable differences from the older 6281?
hwsinn
I am looking to upgrade to windows 10. Any software to recommend for recording shows with my TBS6281?
Previously had problems with NPVR and other softwares. Now i am using Windows media center which is very reliable but no more in Windows 10. Hence i need another software.
albertlee
Previous WMC version can still be install on Win10, just google around.
sunsetbay
Moderator
Moderator
anyone has experience or tried out this yet?
does it work in sg? i thinking of getting it, looks really convenient, dont need to buy a big tv hehe
http://mygica.com/TV-Tuner/DVB-T2-Pad-TV-Tuner-for-android-phone-and-tablet_60.html
i hv this~ tested on S3, lag on HD channels but SD channels are smooth~ most likely its the phone processor problem, though mygica PT360 advertise that it needs only dual core 1Ghz phone~
the bundle loop antenna is less usable, need strong signal area or outdoor to receive properly~ the other bundle bi-polar antenna is better~
anyway, this tuner drains the battery v fast and makes the phone hot, more than using 3G on youtube~ :s22:
numbers
was thinking of getting one to use during reservist lol....
PoloBoiBoi
well ... dvb-t/t2 specs are based on the assumption that you have "unlimited" source of power in the 1st place :s22:
harky
Hi, now a day like no one talk abt this
i loooking for video capture card tht can handle rec video from
VCR
TV box
I looking at this 2 model
Hauppauge Colossus 2
AVerTV CaptureHD (actually i had bad exp with aver.. their app is quite sux)
i1magic
VCR
TV box
Just get MyGica T230 at about SGD$30. Test it and see whether it can meet your needs. If cannot, then search further.
singmob
Many models avail now:
Hauppauge WinTV SoloHD / Solo-HD Triple mode TV Tuner
Avermedia Mobile 510 for Android (EW510)
AVERMEDIA Hybrid Volar T2
Hauppauge 1975 DVB-T2 USB TV Tuner
