[Official] DVB-T2 USB/PCI-E/PCI TV Tuner Thread
maisianmaisian
see latest drivers
TBS Download Center-Update the Latest Window & Linux Driver
TBS6281
1. TBS6281 DVB-T2/T Windows Driver is upgraded to V1.0.0.6. which fixed the driver can't be installed properly from Install Pack.
2. TBS6281 DVB-C Windows driver is upgraded to V1.0.0.6. which fixed some small bugs.
3. TBS6220 Linux Driver is updated to v140323., which has below updating:
* Add support for 5922SE
* Add proper support for retail version of 6922SE
* Add T2 lite support for latest hardware revision of 6221, 6281, 6285
* Add "ClearQAM" (J83B) US Digital Cable support to DVB-C driver for latest T2 lite hardware revision of 6221, 6281, 6285
4. IR software V1.0.0.8 is compatibled with TBS6281.
5. TBS6281 User Guide is updated.
TBS6285
1. TBS6285 DVB-T2/T Windows Driver is upgraded to V1.0.0.6. which replaces the invalid driver.
2. TBS6285 DVB-C Windows driver is upgraded to V1.0.0.6. which fixed some small bugs.
3. TBS6285 Linux Driver is updated to v140323., which has below updating:
4. IR software V1.0.0.8 is compatible with TBS6285.
5. TBS6285 User Guide is updated.
You are back :eek:
LxIxVxE
Senior Mentor
any USB DVB-T2 tuner to recommend yet?
tbs5220 new revision updated to support v1.3.1 standard
TBS5220 USB DVB T2/T Freeview HD TV Stick-Watch DVB T2/Freeview HD TV on Laptop/PC [TBS5220] - US$68.99 : BuyDVB Online Store
but ask b4 making purchase
DVBSky T330 DVB-T2/T/C USB Stick
DVBSky - Enjoy HDTV on PC! DVB-T2 / DVB-S2 Professional TV Tuner Card and Box for PC.
tevii H642 DVB-T2/T/C USB stick
http://www.tevii.com/Products_h642_1.asp
More brands such as blackgold, technotrend, etc is making or updating their products to support v1.3.1 standard
Hauppauge SG no news abt their nanostick riao
always say very soon very soon, but still nothing
they are slow and products expensive
mrsun18
the screen cap is just the tv ad that i happened to capture~ i never say the card got the MDA label~ :s22:
here's the ad~
Yes, I was aware that you did not say the card got MDA label. Unfortunately, the 2 screen shots posted without explanations gave rise to the question of whether they are part of the user's report or just grabs from somewhere. And since the first screen shot showed MDA label together with the channel identifications, I therefore gathered facts as accurately as possible and posted my comments hoping for clarifications.
After reviewing the youtube video, which appears to be a legitimate effort to create awareness of DVB-T2 broadcast in Singapore, several times, I am still unable to locate the 2 screen grabs posted by you in the earlier post.
Edit: Missed the critical phrase you posted: "i happened to capture~". So you already had the card, as pointed out LxIxVxE. Mystery solved:)
mrsun18
If TBS6285 is unable to tune to MediaCorp DVB-T2 signals, I don't see how TBS6281 can receive them. Both products' drivers were updated at the same time.
TBS Releases New Drivers for TBS6285 and TBS6281 TV Tuners
Many thanks for the link and the comprehensive useful info. I checked this download page you gave earlier. For unknown reason it showed a blank page. So I thought the link I gave was the latest.
tan1688
above USB DVB-T2 stick don't support android :(
if could plug into android tablet/phone, then good ahr
watch on tablet/phone
pleeted
thanx u 4 de recommendations.
some qns:
1) does usb dvb-t2 tuner have low quality than those pci-e tuner?
2) does those provide antenna good enough?
3) do we nid 2 take into consideration if we stay quite high and have a few blocks beside our flag, does it affect the signal?
coz i scare i spent so much $ buy this usb dvb-t2 stick then in the end very unclear den nt worth it :(
Aelleroeda
new to tv tuners, need some help here... have been looking at the thread, and am interested in the USB ones for my laptop.... can the TBS5220 watch and record starhub cable channels?
mrsun18
No, starhub carries analogue and dvb-c signals which are not supported by TBS5220.
In any case, most of starhub dvb-c signals are scambled, you can't watch them with you own tuner.
Aelleroeda
Which tv tuner should I get then? Any recommendations (for laptop)?
sunsetbay
Moderator
Moderator
TBS5220 also works on dvb-c as long install the dvb-c drivers, which mean can watch & record all mediacorp SD channels & one HD channel at the mmt, ie. HD5~ :s22:
mrsun18
Thanks for the update. I relied on LxIxVxE's post which did not indicate dvb-c support then for my earlier comments ...
LxIxVxE
Senior Mentor
wow, dun make ur mistake becum my fault reh
never state cos all info inside the product page riao mah
wanna help but failed to read up is ur problem wor
me only here to confirm which pc T2 tuners support V1.3.1 standard
so u assume u noe everything just by reading other ppl's posts :s11:
LxIxVxE
Senior Mentor
some qns:
last time for analog tuners, then u need to worry which tuner will give u the best video quality
but now for digital tuners, all will give the same video quality
everyone get the same video quality no matter wat u use
me got both usb and pci-e T2 tuners
so it depends wat kind u need lor
and only usb tuner will be bundled with a small portable antenna
signal this kind of thing hard to say, need to try to noe
LxIxVxE
Senior Mentor
so far only TBS got the most complete range of T2 V1.3.1 tuners
usb single tuner(5220), pci-e single tuner(6221), dual tuners(6281) and quad tuners(6285) - all must be the updated new revision
other T2 V1.3.1 models with CI not useful for local use
if wanna order TBS tuners, best to get from TBS direct through buydvb
email the sales b4 buying so they can take note of ur order and arrange the new revision to be sent to u, just in case they still got old stock not supporting V1.3.1
this is wat they told me last time
getting TBS tuners from other sources such as ebay or other online store might be old revision not supporting Sg T2, buy at ur own risk
other brands T2 V1.3.1 tuner might be available but not ready for sale
pleeted
thanx 4 de reply. will consider to buy 1 and try.
any idea if hwz got any mo for this (if it is cheaper)?
mrsun18
Play out by this link:
May I say I placed too much trust on you? :)
