bayside
I also did my HA with c.inhaus. I find they are not pushy for sales also they provide very good after sales support.I ping them whenever i am facing some issue and they will resolved it within a couple of days.
btw i heard from the team that they are planning to invite home automation enthusiast to visit and discuss home automation at their showroom in lieu of #C4YOURSELFDAY event.
Depend what is your requirements actually.....
For my house about $4500 for the following:
1. TV and AV integration
2. Lighting
3. Fan
4. 3x Aircon
Inclusive of installation and the good things is 2 years warranty.
You can check out their company C.Inhaus Pte Ltd....
waterfoe
Nice to have another integrated system user.... hahaha..... hope you have a great experience too
porker997
Thanks for your input. Are you also on Control4 package?
Would like to visit their open day. Do you when it would be held? cheers
waterfoe
It a different company.... Both are system integrator.... You can check out both their showroom and talk to them?
Both products will be similar, just that different system integrator will have different solution. So is up to you to decide thereafter.
Thanks. Is HAP the same company as c.inhaus?
Ca5per
Good points. I think for longer term usage, I am prepared to invest into a hub. Looking at the Homey, seems to be versatile across protocols and good reviews so far.
On bathroom automation, thanks for the inputs. I have one more scenario to think about, what happens if you go into the bathroom just to wash hands/brush teeth and the bathroom door is left open? I am assuming the door sensor is only activated on full open or full close. In that scenario, one would only have the motion sensor to keep the lights on?
Cheers
Yup. I have use homey for 2 years and it's very good.
High Compatible (xiaomi, samsung, lg, yeelights, broadlink, aqara, mco and many more)
Have homey voice and also Works with Alexa and google assistance voice.
Easy to configure and setup flow/ routine and friendly using interface. Best is you dont need to invest in any other hub, the smart devices connect directly to Homey.
Sent from Samsung SM-N960F using GAGT
Joshvendetta
Thanks everyone for the smart switch and hub advice!
Amazed at the price difference between Neo coolcam switches (2 gang = $30+) vs. MCO (2 gang = $160?!) Why would someone pay for the MCO switches instead?
Also, noob question here: Are there no such things as 2 gang dimmer switches? I want all 4 lights in my room to be dimmable and they're connected 2-2.
Was so sold on Homey after watching reviews and all.. and then I saw the price :s22: Pretty steep for a first time smart home builder.. Do you guys purchase Homey directly or from other retailers for lower cost?
Ca5per
For homey, neo coolcam is compatible for 1 button switch panel only, that's why i use MCO, up to 4 light switched. Therefore i only need 2 panel for all my eight light switches.
The panel does not come with wording. I diy Chinese wording for my parents to see.
Yes, homey is pricey but very worth it imo. I purchase from local retailer.
Vulpix
Moderator
Moderator
I asked before on the Homey forums and there are people using the 2 gang Neo Coolcam without any issues...
Vulpix
Moderator
Moderator
Better to purchase directly from our local retailer. I watched videos for both and decided to get Hubitat, for some reason I just like the UI for the Hubitat more.
Ca5per
Not sure, but at your own risk. =D
The app did not include them, so yeah.
Ca5per
Hmmm, it says there is NAS-SW01ZE, Touch Wall Switch Dual
https://apps.athom.com/app/com.neo
Does this not count? This not counted as support? I not well versed with Homey.
I see. But i didnt see any dual switch from the app pairing.
If website put support, high chance can. But Neo coolcam only up to 2 gang, mco can go up to 4 gang.
Vulpix
Moderator
Moderator
Well to be fair to Neo Coolcam, the price is 1/4 that of MCO. :s13: Have to be fair to them for not having a 4 gang one.
Ca5per
Yup.
But 1 have to pay extra on installation and wiring works if engaging contractor to do.
So have to consider the total cost also. But as long as it works, it's fine. Hehehe
Vulpix
Moderator
Moderator
Yup.
How did you do your light switch planning by the way? I was thinking of going everything 1 gang other than my dining area and kitchen (2 gang each, one for light and one for fan), like my current home. Might be old way of thinking, so looking for opinions. :D
viix
Only saw MCO has 2 gang dimmer. But the leds lights I've tried so far, doesn't dim linearly. So I've not use my dimmer switches.. Yeah, homey is relatively expensive. But compare the functions to other zwave hubs like the fibaro HC and vera, price wise, provides more value.
I got mine during the presale after the kickstarter for alot less with the MCO switches locally so, hopefully got promo again.
They've update the app, so more functions added as the developer for neo quite active..
Ca5per
My current is 8 switches in living room, controlling service yard, kitchen, dining and living room.
Outside common toilet another 1 mco with 4 gang:
*Common toilet lights
*lights outside common toilet
*1 switch customised to off all light switches in dining/ kitchen/ dining/ living room
*last switch to off main door lights.
raynerho
Hi all, does anyone have any idea what frequencies Eco-Airx and Crestar fans uses? I purchased a Kyla smart IR cube today at the pc show but cant seem to register both remotes to it.
