Dooley
Thanks everyone for the smart switch and hub advice!
Amazed at the price difference between Neo coolcam switches (2 gang = $30+) vs. MCO (2 gang = $160?!) Why would someone pay for the MCO switches instead?
Also, noob question here: Are there no such things as 2 gang dimmer switches? I want all 4 lights in my room to be dimmable and they're connected 2-2.
Was so sold on Homey after watching reviews and all.. and then I saw the price :s22: Pretty steep for a first time smart home builder.. Do you guys purchase Homey directly or from other retailers for lower cost?
I have been using homey for a year.
Worth it if you want flexibility yet ease of use like me. 2.0 pretty much fix all problems like Google assistant native support and app is nice now. is more pricey than rest but worth it given what you get.
I got from local company, still quite responsive now can WhatsApp them late at night still get response!
But usually the homey forum is more than enough, very active and helper people. Looks more active then habitat to me but I guess Homey is older.
My suggestion is work on automating lights first, eg Mcohome smart switch or lights. Also water heater. perhaps curtains but I didnt do that.
my strategy was zwave mcohome switches to create strong zwave mesh.
Those will be the most expensive, the rest can slowly add like motion sensors, IR/RF control of TV & aircon, smart switches and smart lock, door sensor.
I also planned around Google homes.
Sent from Huawei using GAGT
viix
Hi all, does anyone have any idea what frequencies Eco-Airx and Crestar fans uses? I purchased a Kyla smart IR cube today at the pc show but cant seem to register both remotes to it.
Do you already have it? See the remote, it might be RF.. maybe more help over at the broadlink thread
Vulpix
Moderator
Moderator
It's here, thanks DHL!
bayside
I have checked the guys at C.inhaus. They will be opening up their showroom on 8th June 2019 Saturday from 10am onwards. Those who are keen to understand more about c4 systems can pop by their showroom at 21 Woodlands Cl, #09-40, Singapore 737854
Junky_89
May I know if how the neutral wire being installed for the light switch?
Is the electrician will pull the neutral wire from the nearest light point to the light switch?
viix
Do a search in this thread with this link. Answered many times over..
Hainan
Guys,
I'm new at HA.
Where can I buy the Samsung SmartThings Hub 3rd Generation locally?
Is there any diff buying it from Amazon US?... beside not being able to use the zwave (900ish mhz)
topherw86
Those using etouch 20a, how do you connect your ground wire? Instructions says connect direct to back box but.. That means there is no ground connection going through the switch... Is this a concern?
rexonology
Xiao Mi Aqara (No neutral) any good?
Hello everyone! Apologies if this has been asked before, but I really couldnt seem to find my way around searching this thread. I was wondering if anyone has every tried installing the Xiaomi Aqara light switch in their homes?
I was wondering if the switch without the neutral wire would be compatible with most lighting or would it cause flickering of lights if I do not use the special dimmable LEDs?
Or worse, has anyone experienced fires, Connection failure, long lags with the Aqara switch as well?
plustwo
any suggestions for sensors for detecting when someone gets off a chair/bed?
chrisongtj
Guys,
I'm new at HA.
Did you manage to find a solution? I am also researching this
jwillbe
Check out this guide on youtube.
makav31i
Guys,
I'm new at HA.
Why not just buy from Amazon UK...It is £79.42 and they shipped to Singapore...The £79.42 is inclusive of shipping to Singapore...That is around S$140+ for the hub v3...
punkster
Can the gateway hub in Mi Smart Sensor Set from xiao mi Singapore store able to connect to China sever?
Based on personal experience - can connect the gateway but cannot link to sensors. (basically useless) use it as an expensive nightlight
pustefix
I've the Aqara vibration sensor that may work in this situation. It is able to detect vibration when sitting or getting off (but is not able to tell the difference). It works for thin cushion and will not work on bed mattress as they are too thick to register the vibrations. Currently, I am not using it as I have not found a use case for it.
