Hi guys, anyone know whether water heaters need to have neutral wire and if there is and I intend to use a smart switch, does the neutral need to run to the heater ? Currently asked the electrician to run neutral for the light switch but was thinking might be good idea to use a smart switch for the heater as well, hence the question.
Based on my recent experience (<2 months), Your water heater would already have neutral (consider as a power socket 20A, and not a light switch 13A)
Even if there is neutral, you normally can't use the same neutral to power a nearby smart light switch, as the neutral would be coming from a different "rack" of the DB Box (for me it works, not sure why)
For the smart switch for water heater, please refer to link and post below:
lesterchan.net/blog/2016/07/14/using-mco-touch-panel-with-storage-water-heater/?utm_source=search-post&utm_medium=web&utm_campaign=%2Fblog%2F2016%2F07%2F14%2Fusing-mco-touch-panel-with-storage-water-heater%2F%20Is%20it%20the%20best%20option%20for%20a%20fresh%20new%20setup/renovation
forums.hardwarezone.com.sg/122417101-post2465.html
forums.hardwarezone.com.sg/122462643-post2475.html
