Apparently, the only non xiaomi hub that works well with the aqara switches is the homey. but it starts from $599...
Below $400 can get le, but I think I got a returned unit but luckily it’s working fine. Think I am just suay but you can try vesternet. The high price is there because of vat but after you set your shipping it will reduce the price. You can also find referral codes online to get another 10% off I believe.. below $400 no need pay GST but buy at your own risk, though they got warranty.
Hi,
There is no such limitation of 1 gang = 1 light.
Right now, I have Aqara 2 gang switch connected to 6 + 4 downlight, no issue at all.
Something, I found out lately through the Xiaomi app, is that you can reconfigure a main gang to act as a wireless/secondary one. Therefore if you position a 2 gang switch, you could keep 1 gang to act as 2-way, paired with another switch (or run any xiaomi automation). That can be helpful in some configuration, and may worth to reconsider the purchase of 1 gang switch (just go with standard 2 gang)
You mean can get homey at $400?
)Oh... so you are saying... have a spare gang, i can even set to control my lights on 2nd floor and like wise right?
So if i want a button near the main door to off ecwryrhing, i should also keep another spare gang.
Is my understanding correct?
Hi, can I check can the neutral wire be looped? Does that mean one switch down, all those in the same circuit will be down too?
Anyone know where to buy water sensors (to detect rain) that can be supported by Homey? Want to close my blinds when water is detected, to minimise the rain water from blowing in
Update: going to buy Samsung Smartthings water leak sensor. It’s zigbee so Homey should be able to support...
I’m getting a broadlink pro to work with honey. How does the air con remote work if the button presses are incremental? How to link them together?
Yes, that's right.
I just tried it on a Neutral version. There are 2 options:
Convert left button to wireless switch (On/Off)
Convert right button to wireless switch (On/Off)
with the note: The left/right button cannot control the left/right button light after the function is enabled
Then you can add automation for a with the trigger: Single Press on the same gang. I realize you can also add automation whether or not you activate this functionality, so not sure anymore about the real benefit, apart from decoupling the physical gang from the light behind (the light it is still physically connected to, can still be added to another automation though)
Still it won't have as many trigger as the wireless double gang:
Single Press Left
Single Press Right
Single press left & Right
Double press left
Double press right
Long press left
Long press right
My reco would still to think twice about Single gang switch, and go 2-gang by default so you have one more opportunity to trigger automation, unless you don't mind adding a 2nd wireless switch
Hi,
In term of "smart aircon", is there any recommendation from the community?
Has anybody experience the Daikin Smile Series? It provides smart control, but not sure if you can access this functionality outside your house/wifi. The rating of their app on Apple Store is also not fantastic.
Other brand?
I was in a service apartment the other day, where the LG aircon had their "smart" display. I found that having the temperature displayed on the unit itself, is really useful instead of searching for the remote (and you are not even sure that the temp on the remote is the actual, if remote was used out of sight)
lg.com/sa_en/images/AC/features/NSXX2X_Dual-Cool_2016_Feature_08_Simple-and-slim-design_14082017_Desk1.jpg
In term of reliability, I believe most of the people would go for Mitsubishi. How do you make their unit smart?
Can, by right not supposed to but if you see the DB box, all the neutral are looped to one. No breakers for each line since it's not double pole switched..
I hope you did not buy that. The only sensors that work with Homey is the Aeotec, fibaro and the Neo Coolcam ones..
But note that as these are flood/leak sensors, it will require a pool of water to at least trigger the closure. Meaning the rain would have already entered your balcony.
Why not instead use the HTTP app and poll the sg weather website or the data.gov.sg? Im doing it this way to trigger the ziptrak.
Do you have the link to buy?
But if we add neutral, most likely it’s looped right? Does loop = series? Let’s say one of my switches dies, will it break the entire circuit? How will I troubleshoot which one is the faulty one?
Thanks for the heads up.
Is it possible to poll for a certain area for rain? I think the Aqara water sensor works too for Homey but if can detect before the rain even comes that would be good..
Yes, area based. You have to check the API for the location. For me I polled data.gov.sg. there is a small 5min lag behind http://www.weather.gov.sg but ok for pre-emptive measures. Sometimes sudden rain even NEA also lag. Someone shared it on the Home Automation Geeks Singapore.
- platform: rest
resource: http://www.weather.gov.sg/wp-content/themes/wiptheme/page-functions/functions-weather-current-observations-rainfall-data.php
payload: 'station_code=SXXX&hrType=12&tableName=30'
method: POST
headers:
Content-Type: application/x-www-form-urlencoded; charset=UTF-8
json_attributes:
- totalRainfall
value_template: '{{ value_json.totalRainfall | round | int }}'
