viix
My HA rain sensor:
Code:
 - platform: rest
    resource: http://www.weather.gov.sg/wp-content/themes/wiptheme/page-functions/functions-weather-current-observations-rainfall-data.php
    payload: 'station_code=SXXX&hrType=12&tableName=30'
    method: POST
    headers:
      Content-Type: application/x-www-form-urlencoded; charset=UTF-8
    json_attributes:
      - totalRainfall
    value_template: '{{ value_json.totalRainfall | round | int  }}'
Need to substitute the station_code for your desired one. Look at http://www.weather.gov.sg/weather-currentobservations-rainfall/ html.
by scrapping the website or the API? I actually sniff the api and am using that lol..
azsuriel
Hi Guys &
I’m new to this Google Home & Broadlink RM Mini 3 thingy.. really hope to get yr advice how to get GH mini to activate & control my AirConditioning- Mitsubishi Electric Inverter
Also my not smart TV Samsung too..
I’m using IPhone 7.
Thanks Sifu
dareaper
Hello everyone, looking to implement some HA as I am doing renovation now. Was thinking of using Xiaomi aqara switches with neutral wire, but have some concerns that there's no safety logo and hence will have minimum insurance coverage if any of these switches result in a fire. Personally I think the risk is low, but the other school of thought is why take the risk. Is there any smart switches with Singapore certified safety logo?
viix
Nope. no smart switch is certified afaik.. imho get a electrician who is proficient in installing such smart switch and understands the requirements and safety..
zoneguard
You can use normal switch with SG safety mark and overlay it with products like Switchbot or Roome. These products don't use mains electricity if the lack of safety mark is a concern to you.
dareaper
Hmm I went to email enterprise SG / Spring about Smart wall switches and specifically listed the Xiaomi Aqara switch as an example.
The response I received was that an electronic switch is not considered a controlled item, so the safety mark is not required?!
"The onus is for the supplier to know whether the products are electronic or not and to ensure that the product and its accessories are safe rest with supplier."
Anyone knows whether the Xiaomi Aqara switch is considered electronic switch?
HMAN
Indeed difficult to get products with Singapore safety mark due to its limited market size.
Just buy product with CE reference, European standard.
Sent from Google PIXEL C using GAGT
lvlaTr1X
Any recommendation for door sensor? My fibaro door sensor dropped and now its not working anymore :(
HMAN
I have a question about the "Smart Life" / "Tuya" smart sockets.
After it has been setup, if the wifi network changes (eg: the socket is moved to a different home), what is the process to update the socket with the new wifi network?
Reset and setup again.refer to Reset instructions, most of the time, it is non other than press and hold the power button for 5-6 sec while powering up the power strip.
If you did not change the Wi-Fi SSID or password, you don't need to do the setup again.
dareaper
ok answer my own question, it appears aqara defines the switch as an electronic switch on the CQC site:
small poem on rain
since it's not considered a controlled item, no safety mark even if it resulted in a fire, insurance cannot reject the claim?
viix
I forgot where I saw this but if you googled the Spring SG site on the safety mark certification number, some supplier's safety mark is fake..
viix
small poem on rain
By right, all switches and electrical insulation are using fire retardant materials as a safety measure. Same as the pattress box it sits in. If there is any possibility of any electrical arcing, the area which contact the metal and the wire insulation around it will at most blacken and give off a burnt smell but should not catch fire if you follow installation limits and not overload the circuit. The ground wire in the pattress would also ground the sudden current surge and cause a trip at the distribution box.
The more comman electrical fires are cause by heat (overloaded beyond rating) and chemical (battery charging leak/explode), and sparking next to flammable materials like polyester fabric of curtains etc...
You can check out this document from SCDF on the stats to get an idea.
Generally, as long as you do not overload any electrical point, you should be fine. Stick below 50% of the rated Amps to cater for deterioration over time if you are kiasu.
Ie 1A switch on our 240v is 240W and make sure your load is not more than 100W@240AC (note some leds rate their wattage at DC). Also some cheap Led drivers tend to have high inrush current when powering on so get better quality ones..
nico-sg
1.5 month later, I am still struggling to get my contractor to provision neutral wire behind each switches. Keep telling me that we will fail the inspection for TOP if they find out extra non connected wire.
Asking me to add the wire post TOP, which will include some rework/cutting on the false ceiling and additional cost. Has any body gone through this process before?
Neutral wire installation doesn't necessarily mean it is left 'hanging' there, you can ask electrician to terminate it properly until the smart switch installation then remove the screw terminal block or wago connector.
nico-sg
What is this Spring SG company/site? Can you provide link
The other Xiami reseller I am looking at: passionhome.sg?
mantis78
Open source smart plug?
Hi, first post here. Hi all.
Where in SG or even online can I find/buy smart plug like Sonoff S26 that are pre-flashed with Tasmota or ESPEasy? I suck with hardware stuff, and tried and failed soldering a few times even with simpler projects, hence do not dare to approach something as delicate (to me) as this...
Or is there any smart plugs out there that is "open source" enough I can talk to it from a program etc and not relying on their mobile app?
Thanks!!!
zoneguard
Tradfri new items at Ikea SG
Tradfri Signal Repeater: https://www.ikea.com/sg/en/p/tradfri-signal-repeater-80424255/
Tradfri Control Outlet kit (this is basically a smart plug and button combo):
https://www.ikea.com/sg/en/p/tradfri-control-outlet-kit-10364797/
Tradfri Control Outlet, this is rated 13A: https://www.ikea.com/sg/en/p/tradfri-wireless-control-outlet-00364477/
Some new additions to Tradfri carried by Ikea SG stores and online. The control outlets also double as Zigbee routers since they are powered. Supported by Zigbee2mqtt as well apart from using Ikea Tradfri gateway.
Alphas
Since nobody has replied. Yes, once the ssid changed, the device has to be updated. There should be a method to reconfigure the ssid, like press and hold power or reset.
zoneguard
https://github.com/ct-Open-Source/tuya-convert/tree/d9211e0f17641b4af46336c69fd067d0742684ec
Tuya Convert project has just merged in support for newer firmware using TLS: https://github.com/ct-Open-Source/tuya-convert/pull/279
I tried a device using M4dmartig4n's fork on which this pull is based upon and successfully flashed Tasmota.
Once again, you can flash newer firmware Tuya ESP82xx based devices with Tasmota or other third party firmware to be freed from Tuya cloud. List of supported devices: https://github.com/ct-Open-Source/tuya-convert/wiki/Compatible-devices-(HTTPS-firmware). Do note that Tuya has also started using non-ESP82xx chips which cannot be flashed at the moment.
