baineteo
Does anyone know about Yeti? I tried to download it the link points me to an iTunes Store Blank page. A search on AppStore yields nothing.
lampPC
Is anyone using TP link KASA smart switches?
I am using Deco M9 and it includes a smart hub
baineteo
HA and openHAB are software. Hubitat and Smartthings are software but have their own gateways (hardware)..
Ok so i got my aqara switches installed and my Xiaomi gateway paired. Did some basic automation routine but feel that the mi home app isn’t powerful enough. In your previous post you said HA and openHAB are software, however doing some research they seem to require their own gateway as well? Correct me if I’m wrong, but they will not work with the Xiaomi/mijia gateway right?
pustefix
HA and openHAB are software so they depend on other gateways to communicate with Zigbee/Zwave devices. If you are going the HA route, follow this link to setup Xiaomi gateway: https://www.home-assistant.io/integrations/xiaomi_aqara. A few of us are running it this way, HA with Xiaomi gateway, Aqara sensors/light switches/etc.
sj2solutions
We are smart home solutions provider in singapore.
Our switches does not require neutral wire.
Follow our FB facebook.com/Sj2solutions
SJ2Solutions.wordpress.com
kacang2
Hi,
I'm new to this home automation thingy. Was planning to buy Xiaomi Universal IR to automate aircon. May I know if I can use google home to perform its action ?
Epi_curean
Tradfri Signal Repeater: https://www.ikea.com/sg/en/p/tradfri-signal-repeater-80424255/
Tradfri Control Outlet kit (this is basically a smart plug and button combo):
https://www.ikea.com/sg/en/p/tradfri-control-outlet-kit-10364797/
Tradfri Control Outlet, this is rated 13A: https://www.ikea.com/sg/en/p/tradfri-wireless-control-outlet-00364477/
Some new additions to Tradfri carried by Ikea SG stores and online. The control outlets also double as Zigbee routers since they are powered. Supported by Zigbee2mqtt as well apart from using Ikea Tradfri gateway.
Great! Got a Tradfri Control Outlet to try and pair with zigbee2mqtt. it does not appear to be recognised.
zoneguard
I got both the Control Outlet kit and Signal repeater. Both work with zigbee2mqtt for me, I am using version 1.5.0.
Please note that the Mi power plug has an issue with the Tradfri ON/OFF switch from the Control Outlet kit (all the power plugs will trigger on/off when the button goes on/off) and this bug is also resolved with the latest DEV branch of zigbee2mqtt.
baineteo
Hi guys,
Facing an issue with one of my Aqara switches. I can turn on my lights with it, however it will stop responding. After 10-20 seconds, it will automatically turn itself off. I switched out another switch and the other one doesn’t seem to have this problem.
Is this a switch problem? I am using the neutral wire version.
Vulpix
Moderator
Moderator
Hi guys,
What hub are you using to communicate with the light switches?
arcelyn
Hi guys! Been following this thread for a while now. Now that my house is fully renovated, I’m trying to set up and utilise the home automation.
Opted for Homey system and MCO switches to begin with. Still slowly building up more compatible appliances with the system. Read that there are some experienced Homey users here as well, do we have a Homey thread or Homey telegram group that can bounce idea and offer assistance? Have some issues setting pairing the MCO dimmer switch and also wanna know more about using the spare buttons in the switches to control other switches! Help appreciated:)
baineteo
Already turned off my gateway to check if it’s an automation issue or not. Removed everything from the app as well - not too sure what’s happening. Don’t think it’s an automation issue.
jolin90
Hi guys! Been reading this thread for a few days as both myself and hubby are quite techie. Would like to do up some smart stuff for our EC. Originally was hoping that an ID can help in such stuff but most look quite unsure. Seems like most probably we have to engage someone or even DIY.
Our main concern is wiring and switches which both of us are not sure. For hub, I think we should be able to handle the programming involved for some hub and also saw some popular names like SmartThings, Hubitat or Homey seems quite manageable.
We are also planning to get Sonos, motorised blinds (read about Somfy, Dooya etc) and many smart AC.
Was there a poll on the hub/switches that people use here? Quite overwhelming as the options and prices seem to vary a lot. Only started reading this week so please bear with me.
Alwaysb
I met my electrician today. I intend to move my meter box about a meter. He told me i can for non inspection. Without inspection i can do netural wiring and relocation of wiring.
I asked him a few times, he said many do not opt for inspection for landed house because it is alot cheaper.
If opt for inspection, then whole house need rewiring. I also confused now.
Who is suppose to so the inspection during top?
1.5 month later, I am still struggling to get my contractor to provision neutral wire behind each switches. Keep telling me that we will fail the inspection for TOP if they find out extra non connected wire.
Asking me to add the wire post TOP, which will include some rework/cutting on the false ceiling and additional cost. Has any body gone through this process before?
hotpick
Hi guys, my Broadlink TC2 3 Gang bought last month from a local seller who claimed it is the 2019 version with built in capacitor, suddenly can't power on again today with no backlight like totally no power. The whole 3 gang works again only after I turned off its power at main circuit breaker, open and close its glass panel and turn on the power again.No light flickering issue so far and this is the 3rd time I encountered it in less than a month.
Anyone had this issue before? Switch faulty? Thx.
viix
Is the dimmer model supported?
https://apps.athom.com/app/com.mcohome
What issue are you having? It should pair as generic zwave device if its not supported. Bring your homey closer (power homey with a power bank).
To link with another switch, use association groups in the device setting
viix
Hi guys,
Could be a faulty switch..
