Yes confirm. Neutral will not exist in your light switches. Because it’s redundant to lay down from the ceiling to the light switch and then to go up again. Neutral is return path back to your distribution box. For single phase, ie HDB, neutral can be taken anywhere. ( This is not the case for 3 Phase, as L1 N is different from L2 N ) So what he can do is to see if there is any nearby 13A PowerPoint and take the return from there, provided that there is such point nearby. If dun have, then the only way is to take from your ceiling.
But remember, by doing the first method to take N from 13A PowerPoint contravene CP5 Standard’s, which is SG electricity regulations.( return path must follow same radial connection back to your DB ) Which is now known as SS638 standards, while it solves your issue , it’s not a recommended method.
