cosycatus
Thanks for the reply
Another question. When pulling neutral , is it for each lamp or fan , is 4 gang switch will have 4 neutral to connect to it or will 1 neutral to the switch to be shared by 4 gang will do?
taokay
Many thanks for this! I was also looking at Aliexpress, comparing Aqara, Lonsonho & Avatto. Out of which, Avatto is the cheapest, hence I'm likely looking to get that (the rocker switch version):
Good to know that someone else is also looking at the same platform (Aliexpress) for purchase and eyeing the same brand!
Am still awaiting my ID for a quote on the electrical works.. Thanks for your info, gives me any idea how much it'd be... I'm looking at around 10 switch points, but each with different connection points (1 to 3 lights/points); would each switch point still be quoted as the same cost this way
which brand did you go for in the end and how has it been for you so far?
am in the midst of renovating my place and kinda urgently require a brand of smart switch. I believe plenty of new home owners are like me, lost in the huge mess of smart home brands and the recent Aqara incompatability issues with google assistant just makes the purchasing process much tougher.
would appreciate any help and experiences so far!
[got to remove the url in original post]
Alphas
Only one neutral wire needed for each switch, though note the max amp of the wire is typically 13 A. Another possibility is to replace with self-powered switch to avoid the wiring mess in the previous post.
simwb90
my small little project on raspberry pi 4 + home assistant
man cave hahahahas
how did you get the CAD? did you have to model it yourself?
it'll be useful if you could share the components of your setup (what switches, lights, etc)
snowblaze
Aqara switch recently got problem?
taokay
I read somewhere that their china hub cannot be used with google assistant. Have to be the global/EU hub. But that means that u have to use a global version of the switch which is not yet released. The china versions all not compatible with google home anymore.
i think this only affects new users. I also saw some people here saying that their aqara stuff not showing in google home app in previous posts.
just want to make sure i have a good and reliable brand of switch before proceeding as they are rly pretty pricey.
holy1god
man cave hahahahas
For the floorplan, i use hdb given 2d floorplan and make it to “to scale” 3d floorplan using sweethome3d.
For the home assistant, Consist of many custom plugin, example weather card, apple homekit logo button etc.
For light switches, using smartlife zigbee no neutral no capacitor with able to support ceiling fan touch panel switch.
cosycatus
Paiseh, can clarify when u say switch do u refer to one on/off switch ( that can consist of 1 to 4 gang ) or a switch that contains a gang of 4 on/ off switch.
Another way of asking, I buy a 4 gang swtich to control 4 lights. How many neutral do I need to pull?
simwb90
awesome. was also using sweethome3d for my draft floorplan.
thanks for the share.
how is zigbee so far?
snowblaze
Thanks. I wanted to buy aqara switch also...
however I went for Yeelight
simwb90
Zigbee so far so good. Been using for 1yr plus, no malfunction or auto un-pairing
i know you said there wasn't a need for neutral wire. so how did you wire them to your sockets/switches?
did you have to remove the faceplate, wire them and keep it inside the mounting box?
i'm thinking of trying Shelly-1 but was consistently told by others that its probably not gonna fit after all the wires are done up...so haven't gotten round to trying it.
holy1god
mine is a 4rm bto, so by default there isnt any neutral wire at switch area. if u got pull neutral wire previously, actually the switch can tap neutral wire too if u have neutral wire, althou is optional
dereklim1985
i also thinking tuya or aqara light switches, but i really dont know how is their compatiblity recently after reading quite alot of forums..
Alphas
Here is my home assistant on an old raspberry pi 2 in development. All the switches are smartlife/ tuya UK plug except aircon are Sonoff Pow R2. There is local tuya integration on home assistant that enable internal wifi connection without internet, so it possible to control them when the internet is down.
However, my cove lights are on Magic Home app which is not supported in home assistant, I could only conttrol using Amazon Alexa or Magic home and not home assistant. So I think is better to keep all the smart devices in one ecosystem, tuya/smartlife devices have the largest varieties rather than to mix different brands and makes of the devices.
Alphas
Only one neutral, 4 gang switch requires one live in, one neutral and 4 live out. Basically, the neutral is just to power the internal electrical circuit.
Alphas
man cave hahahahas
Previously, I have watched a 4 parts tutorial on how to create those nice 3D CAD rendering of the lovelace UI on home assistant. Very informative guide and he explained very clearly. But need to spend hours to create such an 3D interface, maybe I will do this when I have too much time on hand LOL.
This is the first part tutorial, the rest are on his channel.
IceX
Anyone has issues using BroadLink with their Mitsubishi aircon these days ?
all along it was fine for me until the past few weeks. Couldn’t work. Tried to set up again and still the same thing.
