Anyone knows what are the smart lights that are compatible with aqara? Can aqara smart lights work? Heard only can pair frm mainland server.
are you wiring the smart bulbs to a smart switch? if so, why?I have the M2 aqara hub, aqara smart switches and installed Ikea's tradfri gu10 bulbs in my new place.
I currently have tradfri and Philips hue bulbs connected to my philips bridge at my current place. I'll migrate everything over when i move but don't see any issues with the aqara / Philips / tradfri combo.
hope i got your question right. are you asking if the smart bulbs are connected to the light fixture that is controlled by a smart switch?are you wiring the smart bulbs to a smart switch? if so, why?
why not?are you wiring the smart bulbs to a smart switch? if so, why?
with a smart bulb isn't the idea to leave the switch as always "On"? so why is there a need to control the switch itself?why not?
I did the same too. U can control the switches regardless of its state.
can save power also. Maybe i traditional, I prefer to have physical controls which isn't a rocker and can switch on/off.with a smart bulb isn't the idea to leave the switch as always "On"? so why is there a need to control the switch itself?
it doesn't really save power, a smart switch in "off" state also consumes power. understand the visitor scenario, but that seems quite an edge case. the conventional wisdom nevertheless is to go for either smart switch, or smart bulbs, which i can understand doesn't apply to you or comcrepe, but just wanted to leave this out there for the wider audience.can save power also. Maybe i traditional, I prefer to have physical controls which isn't a rocker and can switch on/off.
you also don't want to have someone coming to your house control the rocker where you ended up having to turn on manually before you can return to your on/off state for the bulbs. It gives you the flexibility too on lights/bulbs.
Hi @swanage18
Yes, you're correct - Aqara is integrated to Google home.
Of course - there are 3rd party providers for that - e.g Home @uto. It will cost more though
There are many other switches that you can get besides Aqara - the Tuya switches are gaining traction here in this thread too.
For aircon - you just need a IR blaster only - no need for M2
There are cheap IR blaster out there - around $10:
Curtain motor/ tracks from Taobao or online is alrite. There are contractor in Carousell that does smart curtains - you can check them out.
For Aqara if you get the international version (and connected to their OTHERS server) - response time will be better. For Mi Home to function well - you'll have to connect to their China server which will be quite laggy.
https://www.ema.gov.sg/cmsmedia/Handbook/Poster_Cable_Colour_Code_Change.pdfHello all.. Trying to install this. Where does the yellow/green wire go to? It's a fluorescent tube light
So put the live and neutral on to the switch and leave the earth as is?
Cannot tell from picture how the earth wire is connected. But the termination block got the Earth symbol for the earth wire that is screwed in.So put the live and neutral on to the switch and leave the earth as is?
It's connected to thisCannot tell from picture how the earth wire is connected. But the termination block got the Earth symbol for the earth wire that is screwed in.
The ballast requires the earth connection. Please get an EMA licensed electrician since you are dealing with live current here.It's connected to this
Leave the earth as it is, don't disconnect. but as zoneguard advised, best if you get professional help, since you are asking this basic question.It's connected to this
Yep ok thank youLeave the earth as it is, don't disconnect. but as zoneguard advised, best if you get professional help, since you are asking this basic question.
