lance88
I have aqara switches, switchbots, mi home to control lights, curtains and mi products. Others app includes kaadas for door and ecovacs for robot vaccum. Any advise on how to automate them since they are all from different apps?
comcrepe
I have aqara switches, switchbots to control lights and curtains. I have 2 enquires,
1. Is there a way to control Aircon via app ?
2. I have yet to get Google nest hub, what is the function to get this device? Is it usually for control over voice?
If you have the aqara m2 hub, you can control your aircon via the aqara app.
the Google nest hub can also act as your home control unit.
tbl12345
Moes is ok,
If you plan to use homekit in the long run, then maybe aqara is for you
My own setup consists of aqara sensor, and mix of tuya/ewelink devices and use homeassistant to integrate them all.
One capacitor installed per switch, not per gang. To make it easier, you just grab the non neutral, no capacitor required by moes.
Adding neutral wire benefits you if you’re using zigbee switch (repeats zigbee signal).
If you’re using wifi type, just make sure your wifi coverage is good.
Hi all, noob here.
If i am intending to put motion sensors in the kitchen and toilet
1) do i still need a switch?
2) do i still need a smart switch?
lance88
My Aircon is not connected to aqara switch, so I was thinking what way is there to make it controllable via app.
If voice control was not smth I go for, what else can this nest hub be used for?
comcrepe
what i meant was, if you have aqara switch, you should have the aqara hub to control the switches.
the aqara m2 hub can control the aircon via IR.
if you don't have the aqara hub, how do you control your aqara switches?
comcrepe
Hi all, noob here.
it depends on what motion sensors you get.
if you get the Philips hue sensor, then you only need the Philips hue bridge and light bulbs. a dumb switch will work but you need to keep the dumb switch on. otherwise your hue light bulbs won't turn on. the hue motion sensor will turn the bulb off.
but if you get the aqara motion sensor, you can use their aqara switch and pair it with normal light bulbs. the motion sensor can turn the switch off.
Slavor
Hi everyone, would like a confirmation from those alr using Aqara switches and hub.
If I use a global Aqara M2 hub (bought locally) with D1 switches from Taobao, it should have full functionality with Google assistant and HomeKit right?
Thank you very much for your help!
brokenx
hi everyone,
is there any universal remote control that supports 2.4G frequencies? wanted to control my LED lights but they use 2.4G
Shadowlite
Hello, anyone knows of any 20A smart switch (for water heater) that doesn't require neutral wire?
Seems like all the smart switches for water heater required neutral wire to work ...
https://shopee.sg/product/116701656/6947648674?smtt=0.76966090-1645419191.9
20A switches requires neutral wire to work, even for non smart ones. It's for safety reasons. You can check online, there shouldnt be any 20A heater switch (even non-smart ones) that does not require neutral wiring.
flikmy
Am doing something similar. Bought M2 Hub Global version from Aqara Singapore and then bought D1 switches from Shopee (delivered from China). On Aqara app, am logged on to "Other" region and all my D1 switches from China work on both aqara app and Homekit. I don't use Google Assistant though.
runforyourlife
Moderator
Moderator
For those of u installed, when you shift house, does the vendor come and relocate for you at a fee?
ferbulous
Hi all, noob here.
Well, there's also the non wifi motion sensors where you can just hook up directly to your existing lights
ferbulous
Anyone here use radar sensor (rcwl-0516) for room occupancy?
Does it get too sensitive that it detect movement across different rooms?
Hello everyone, happy Friday! I have a rather noob question, hope you guys can help me out as I can't find the answer after googling or rather maybe I am not searching it accurately using the correct terms.
The scenario is that I bought a Yeelight M2 pro from Taobao to test. It works great as a normal downlight but I can't test the smart features as my new place is still under renovation without an internet connection.
I was thinking of testing the smart features at my current place since I have the hub but my current place is a rental and I don't think tinkering with the lighting might be a good idea.
So the noob and (maybe dumb) idea I had was to see if I can hook up the downlight (the driver is built-in the M2 pro) to a 3 pin plug and power it using a wall socket so I can start playing with the smart features.
Might be a totally dumb idea lol
shin7829
Any expert electrician here!?
Lets not talk about heater smart switch, this for sure need neutral and will have neutral
For smart switches for lights , some say no need neutral line if dont have just get non neutral switches.
Some say must pull neutral line and get neutral switches.
Then some say just out a capacitor if really no neutral line. For capacitance what values should i be getting?
So is need or no need neutral
shin7829
since you have the equipment u should try leh.
I dont have yet so i cant try
