Shadowlite
Hi Alphas, that's right. I am looking for Smart home devices to set up scenes. I was wondering if I add the Tuya wireless controller to the dumb controller, would that make it smart?
Thanks. Shadowlite for the tip too.
Would this be the correct setup? I think I will get a 1m strip to test and also to explain to my ID how to do it haha
Transformer > Tyua Wireless Controller e.g. GLEDOPTO > CCT LED Strip
I was thinking of connecting to this LED tester that I bought https://www.lazada.sg/products/i1984454258-s10735959158.html?urlFlag=true&mp=1&spm=spm=a2o42.order_details.item_title.1
The setup is correct (Driver => Controller => strip).
As pointed out, there's no need to get a 1m strip just to test and explain to ID. Most electricians should know how to connect it, as in my case even though my ID knows nothing about smart devices, his electricians knows how to wire all the stuff.
Just get what you need, so long you are comfortable dealing with electronics.
If not, would suggest you to get those off the shelf products like Govee. They have IP22 / IP65 versions, which would mean they are thinner and more flexible than Willow.
COL Juay
Been reading quite a number of threads and decided to share my set up to ask for some opinions.
Type of lights: (Yeelight, hopefully more reliable and good quality)
1) Cove - Yeelight wifi LED light strip from Taobao (much cheaper at S$60/12m including driver and controller all in one) (should be same as Willow but TB never indicate)
2) Downlights - Yeelight M2 Pro from Taobao or Lazada (China export) ~S$20/unit
3) Ceiling lights - Yeelight LED ceiling light series from Taobao (much cheaper) ~S$50-S$100 depends on size and series
Type of sensors: (brand undecided)
i) Contact sensors for door to trigger automation (open main door, downlight turn on)
ii) Motion sensors (enter kitchen, lights turn on. no motion detected after 10mins, lights turn off)
Type of switches, remotes and controllers:
Comparing between Tuya (MOES) or Aqara based on:-
a) Cost of switches and requirement for additional hubs (Tuya MOES seem to be slightly cheaper and more options than Aqara)
b) Prefer to have a physical bluetooth remote or wireless switch rather than controlling thru APP (everyone at home can use and lights will react faster) - Tuya MOES seems to have quite a lot of wireless switches and remotes, but unsure how good are they
c) Will also use Google Home voice control as secondary control since I am concern that it'll lag and take a while to react to commands (high failure rate)
d) availability of ONE button scene selection, OFF all lights (e.g. MOES 4 Gang Tuya ZigBee Wireless 12 Scene Switch)
Questions I have:
Q1 Do I need 2 hubs, 1 for yeelight non-wifi lights and 1 for Aqara/Tuya? Any chance I can get a hub that controls all?
Q2 Does Tuya / Smart life app play well with controlling yeelight(s)? OR it's better for me to go Aqara and use MiHome app?
Q3 When setting up, can I add the yeelights to the Smart life app or I need to setup on Yeelight app (assume I can sync or link the yeelight app to Smart life app)
Shadowlite
Questions I have:
- Do I need 2 hubs, 1 for yeelight non-wifi lights and 1 for Aqara/Tuya? Any chance I can get a hub that controls all?
- Does Tuya / Smart life app play well with controlling yeelight(s)? OR it's better for me to go Aqara and use MiHome app?
- When setting up, can I add the yeelights to the Smart life app or I need to setup on Yeelight app (assume I can sync or link the yeelight app to Smart life app)
Q1: You will need bluetooth gateway for the Yeelight, and no, it's not universal.
Q2 / Q3: No, they are on separate platforms, so Tuya app cannot control Yeelight and vice versa.
The answer is simply no. LED controllers cannot be connected in series, they do not work in this method. Also it is not necessary to get a LED tester when you know what you are doing. Save the money for better transformer or LED controller.
If you need a Tuya smart LED controller in addition to a RF remote, there is one LED controller that supports both methods of control. LM051-EUT091 has both RF remote and can be controlled via tuya app.
https://www.lazada.sg/products/24g-...ontrol-12v-24v-i1987954599-s10765190535.html?
Thanks Alphas and Shadowlite for the guidance.
@Alphas I happen to have a LED tester which a member recommended earlier in this thread to use to set up a M2 pro for testing since my new place has not electric works done yet :)
Questions I have:
Hi @COL Juay,
I am still noob to this and am still exploring but don't mind what I learnt and experimented :)
Thankful much to the bros who have given their valuable tips.
The Yeelight willow is a bit thicker (2.5cm width) and less flexible than normal LED strips which my ID feedback that it is quite difficult to sit flush even with the included clips. I would have gone for this option too since it is cheaper than Yeelight pro.
I bought a unit from TMall to test. I am waiting for my LED tester to arrive to test the smart feature and if it can work with my Smart Things hub since it is suggested that ST has YeeLight integration. The good news is that the model number is exactly the same as SG, which leads me to think that there is no difference. However the lm specs for CN is listed as 500lm while some of the local sellers on Lazada or Shopee list it as 600lm. The official Yeelight SG page list it as 500lm. From where I read, the M2 Pros are just BT Mesh receivers, it is the gateway that is most critical in the setup. Thus I will be buying a local BLE gateway should my Smart Things hub is unable to connect.
Good idea, I am looking for a unit too!
I chose the Aqara D1 switch (about $30) from Taobao. Have installed it and it works. Would have loved to get the H1 but it is really expensive (about $80). Have confirmed with the local Aqara distributor that the D1 and H1 functionalities are the same. Only the design and the materials used are different. D1 is ABS plastic, H1 has a metal frame and is fully flushed.
Smart Things have native integration for Yeelight and driver (for lack of a better description) for Aqara. I have tested my Aqara D1 with Smart Things using driver from Github as per Alex (@Evilbear) walkthrough. Will test my M2pro when my LED tester arrives.
COL Juay
So I will need 2 separate hubs. 1 for the yeelight, 1 for the switches
Do you know how will the 2 different hubs communicate with each other?
I think the hubs are transmitters and the device like Aqara switches are receivers. The hubs don't communicate with one another. You will need to integrate everything into a platform like Google Home to create scenes. The hubs will just talk to the devices assigned to them as child?. After which you can integrate them all into Google home or Alexa to create scenes by linking the different branded apis in Google home/ Alexa.
When you ask Google home to say movie time (or netflix and chill LOL), it sends the command to the different hubs to trigger the actions from the respective hubs.
Haha hope my concept is correct!
Alphas
Thats right, the hub/gateway are translators for the communication protocols, eg Zigbee. Basically, it is always better to stick to one ecosystem since different brands may not be compatible to another brand gateway/hub even on the same Zigbee/wifi standard. Personally, I will prefer smart devices on the tuya platform since it has the largest ecosystem of smart devices.
This youtube on Zigbee explain it quite well.
Shadowlite
Think most of the replies are quite accurate. In essence, they don't / can't communicate with each other (as of now, not sure if things will change with Matter). The only thing you can do with the two platforms is to integrate with a voice assistant like Google Home, but that would only allow you to control each of them individually (Not sure if you can do more things with Alexa and HomeKit as I'm not on those platforms). If you are looking for things like for example: Tuya door sensor talk to Yeelight bulb (i.e. door open light will open), then you need something to bridge between them. Some examples would be IFTTT, Home Assistant, which are automation platform that talks between the different smart home ecosystems (e.g. Tuya <=> IFTTT / Home Assistant <=> Yeelight)
If you want things to be simple, just use a single ecosystem like Tuya. Issue with Tuya is that they don't manufacture hardware, but are simply provider of a smart home platform and expose their APIs for OEM manufacturers to use. So you have to do your own homework to find a good manufacturer, as quality of the device is a hit and miss with the various OEM manufacturers out there.
Personally for me, I use a mix of Aquara, Yeelight, Govee, Tuya, Xiaomi devices according to my needs, and I automate them using Home Assistant
COL Juay
Thank you for the video and explanation! Will you be able to share wwhat lights youre using with Tuya platform? I see good switches, hubs, sensors
I'm looking for dimmable downlights, LED strip and ceiling lights.
Evilbear
Step 1 to planning your smart home is to decide what platform you want:
1. Google home (no device automation)
2. Amazon Alexa (lack of support in our region)
3. Apple Homekit (only for iphone)
4. Xiaomi miHome (only integrate with china brands)
5. Home Assistant (not easy once you want to set something that is not 'out of the box')
6. SmartThings (not local automation unlike other hub based options)
7. Homey (very expensive)
8. Hubitat (no sg warranty)
9. IFTTT (cloud based subscription, limited to available connectors)
And no, Tuya or Aqara are not a platform. Their app only apply for their own brand of devices. You cannot integrate other brand of devices into their app, hence you can't set cross brand automation.
Yes, they have a wide range of devices, but you are still limited to do automation within their own platform of devices if you don't consider one of the above listed platforms.
Evilbear
As explained accurately here about Tuya. Might as well go with local brands that have IMDA approval, safety mark certifications, quality assurance and even have warranty support. Brands like Ganen, Koble, Near and even MADS going to come out with her own product too. All leveraging on Tuya Developer.
Alphas
Firstly Tuya is a platform that allows developers from other brands make smart devices and IoT for their app. Voice assistants such as Google home or Alexa would then integrate various brand of devices to allow automation across various platforms.
darcbleu
anyone can recommend any smart home automation company that can do up my 3rm HDB at reasonable price and reliable?
saw many ads ranging from $800 to almost $2k.
can PM me if you ok. thanks.
COL Juay
For smart lights to work, I understand we need to keep the physical switch in ON status.
If I am already using a smart light, it doesnt make good sense to use another WIRED physical smart switch to control it.
Any suggestion what switch can I use to achieve this always ON status? (instead of keeping a dumb switch permanently on, family members tend to turn off the switch for ease of operation)
Alphas
Don't use a physical switch, and connect it directly to the lighting circuit. There will be a very small standby power so get a high efficient transformer or driver.
COL Juay
Can I clarify, by connecting directly to the lighting circuit, it will mean, I cannot turn off/on the lights by a wired switch anymore right? It will be in a permanately ON state?
All controls will then be through app or a wireless switch right?
Shadowlite
Actually it makes more sense to get a wired smart switch if that's what you want, as you would want the flexibility to turn off the circuit if you need to replace the smart light. If you connect directly to the lighting circuit, you would need to use the circuit breaker to turn off the power supply.
Unless that is something you would want, always have a convenient means to turn off the circuit for safety purposes.
