Shadowlite
Hello everyone, happy Friday! I have a rather noob question, hope you guys can help me out as I can't find the answer after googling or rather maybe I am not searching it accurately using the correct terms.
The scenario is that I bought a Yeelight M2 pro from Taobao to test. It works great as a normal downlight but I can't test the smart features as my new place is still under renovation without an internet connection.
I was thinking of testing the smart features at my current place since I have the hub but my current place is a rental and I don't think tinkering with the lighting might be a good idea.
So the noob and (maybe dumb) idea I had was to see if I can hook up the downlight (the driver is built-in the M2 pro) to a 3 pin plug and power it using a wall socket so I can start playing with the smart features.
Might be a totally dumb idea lol
You can use this. https://www.lazada.sg/products/i1984454258-s10735959158.html
That's what i got to test my M2 pro and other downlights, do note that you'll need the bluetooth gateway to control the M2 Pro.
Shadowlite
Any expert electrician here!?
Lets not talk about heater smart switch, this for sure need neutral and will have neutral
For smart switches for lights , some say no need neutral line if dont have just get non neutral switches.
Some say must pull neutral line and get neutral switches.
Then some say just out a capacitor if really no neutral line. For capacitance what values should i be getting?
So is need or no need neutral
It's not about expert electrician or not.
It's a matter of whether the smart switch you get supports non-neutral configuration.
Whether need capacitor for the non-neutral switch also depends on the switch itself. For example, those SMATRUL wifi switches will need a capacitor for the switch if you are using in non-neutral mode (Included with the switch). On the other hand, there are zigbee switches from MOES that does not need capacitors even in non-neutral mode.
The reason for using a capacitor is cause of how non-neutral smart switches work. They stay online by allowing a small current through to one of the gangs (most commonly gang 1), i.e. acting like a dimmer. As there is a small current flowing from the switch to the light, some sensitive lights will display the 'flickering' effect. That's where the capacitor comes in: to stop the current from flowing to the lights so the flickering stops.
For value of capacitor, that one would be best if the switch you get comes bundled with the capacitor, as it should likely work out of the box.
As for the pros and cons of neutral vs non-neutral (other than the need to pull neutral wiring), from what I read as appliances connected to the non-neutral switch will have a small current flowing through 24/7 (thus the need for capacitors for some appliance), some people say it might decrease the life span of the appliance (not confirmed). The other difference is that for some zigbee smart switches, if they are connected to neutral, they will act as zigbee routers also, thus helping with strengthening your zigbee network.
So is need or no need neutral? Ans is: you do not need neutral, having neutral just gives you more options on the kind of switch you can get.
batniss
use hotspot with a spare phone.
i did that. simple and easy.
hey guys, anyone have experience with installing smart zigbee switches for 2 way function? From what i understand from my chat with the seller, one side connects to the light and power, the other just connects to the power. The two way function will just be set via the app.
Seller doesnt recommend to connect switches on both side to the lighting point as it may short circuit.
Below link is to the product i bought. Appreciate any advise.
https://www.aliexpress.com/item/100...1;27.06;-1;-1@salePrice;SGD;search-mainSearch
lance88
Is soldering/electrician skill required for capacitor to be identified where and solder to install?
batniss
can be done but no issue doing what the seller said too.
no
Ok, do you mean connecting both sides switches to a single light is doable as well? Other than what seller recommended.
How would you do it, and are there any other methods i'm not aware of to enable 2 way function?
Thanks!
Thanks bro for the quick tip, I ordered one last weekend to try.
@shin7829 will share my testing results with you.​
BTW in case anyone is interested to know, I bought a D1 Aqara switch directly from Tmall and it works very well with my Smart Things hub. Thanks to Alex's (Evilbear) simple and easy to follow tutorials.
Does anyone have any lobangs on smart LED Strip with cool and warm colours? I am looking for a couple for my carpentry. My ID was not keen to use the Yeelight Willow as it is too thick and rigid. The other option is Yeelight pro LED strip but the cost is quite high per meter.
Alphas
You can simply buy those 5050 LED strips from aliexpress at 60 LED/m for good brightness. Get a LED controller from tuya or magic home and connect it to a 12V, 5A adapter for 5 meter strip.
This is interesting, thanks for the suggestion!
Wanted to ask some noob questions, sorry to bother. If I get LED or COB lights that can change color cool - warm white, can I just use this Tuya controller to change brightness and color?
Alphas
No question is noob. For changing warmness of color, cool - warm, you need to get a Correlated Color Temperature (CCT) LED strip and the suitable LED controller that support CCT LED. Check my thread I did during the renovation for my RGBWW led strip for the cove lights. If I remember correctly, magic home may not have CCT LED controller, so you need to get the controller from tuya. One example is this
https://www.lazada.sg/products/wuli...ontroller-work-i2026063790-s11047591570.html?
You will also need LED amplifier when the strip exceed 5 meters.
Hi Alphas, that is pretty insightful. I think my ID is really not that familiar with smart LED. The one we saw at the lighting shop can change color temperature using RF remote. I suppose the concept is the same just that I need to add the Tuya wireless control in between the transformer and the LED strip? I am also assuming that LEDs itself are just normal light strips, it is the module before that that makes them smart :)
I was thinking of getting a set of LED strip, Tuya controller and transformer to test (are these the items I need?) and wire them to the LED tester I bought to test my M2 :D
Any recommendations on where I can find them in SG?
Shadowlite
As @Alphas mention, you can get a 5050 WW/CW strip and a smart LED controller. A good one is GLEDOPTO, which I am currently using. You'll need to connect it to a LED driver (Transformer), which is connected to the mains. This means that you can connected it to a light switch to turn it on / off physically.
If you don't need to connect it directly to the mains, you can consider Govee, which is a WiFi LED strip. As it connects to a power socket, you don't need to install a light switch for that. I use this for carpentry where I don't need to install a light switch like TV console. Advantage is that it's plug and play, no need think so much.
For LED strip, there's a wide range, depending on what are your needs (i.e. density or leds per metre, size of strip, type [5050 / 3825 / 2835])
Controller depends on whether you want wifi or zigbee, there's Tuya and GLEDOPTO
LED Driver would recommend Meanwell. for the wattage it'll depend on what LED strip you get, normally the shop can recommend you which wattage driver to get.
I got mine separately from Lazada and AliExpress. Amazon for Govee
Alphas
Hi Alphas, that is pretty insightful. I think my ID is really not that familiar with smart LED. The one we saw at the lighting shop can change color temperature using RF remote. I suppose the concept is the same just that I need to add the Tuya wireless control in between the transformer and the LED strip? I am also assuming that LEDs it self are just normal light strips, it is the module before that that makes them smart :)
I was thinking of getting a set of LED strip, Tuya controller and transformer to test (are these the items I need?) and wire them to the LED tester I bought to test my M2 :D Any recommendations on where I can find them in SG?
Those RF LED controllers that do not connect to wifi/Zigbee are probably "dumb" controllers. That is, it can only be controlled by RF remote, cannot be integrated with Google Home, Alexa etc. If your objective is an integrated smart home devices, then you want to see Tuya/Zigbee/Magic home compatible LED controllers. I do not get LED strips or controllers in lighting shops, they tend to "chop" customers, once I seen a 5 m LED strip cost 10 times as what I could get online.
Hi Alphas, that's right. I am looking for Smart home devices to set up scenes. I was wondering if I add the Tuya wireless controller to the dumb controller, would that make it smart?
Thanks. Shadowlite for the tip too.
Would this be the correct setup? I think I will get a 1m strip to test and also to explain to my ID how to do it haha
Transformer > Tyua Wireless Controller e.g. GLEDOPTO > CCT LED Strip
I was thinking of connecting to this LED tester that I bought https://www.lazada.sg/products/i198...mp=1&spm=spm=a2o42.order_details.item_title.1
Alphas
I was thinking of connecting to this LED tester that I bought https://www.lazada.sg/products/i1984454258-s10735959158.html?urlFlag=true&mp=1&spm=spm=a2o42.order_details.item_title.1
The answer is simply no. LED controllers cannot be connected in series, they do not work in this method. Also it is not necessary to get a LED tester when you know what you are doing. Save the money for better transformer or LED controller.
If you need a Tuya smart LED controller in addition to a RF remote, there is one LED controller that supports both methods of control. LM051-EUT091 has both RF remote and can be controlled via tuya app.
https://www.lazada.sg/products/24g-...ontrol-12v-24v-i1987954599-s10765190535.html?
