Alphas
Can I clarify, by connecting directly to the lighting circuit, it will mean, I cannot turn off/on the lights by a wired switch anymore right? It will be in a permanately ON state?
All controls will then be through app or a wireless switch right?
You can have one or the other and not both.
ferbulous
For smart lights to work, I understand we need to keep the physical switch in ON status.
If I am already using a smart light, it doesnt make good sense to use another WIRED physical smart switch to control it.
Any suggestion what switch can I use to achieve this always ON status? (instead of keeping a dumb switch permanently on, family members tend to turn off the switch for ease of operation)
That’s kinda expected with other family members not familiar with it
1) put a sticker on it not to turn off?
2) wifi/zigbee switch and set automation to always on even if someone turn off.
3) like other people suggest, connect directly to mainline
4) saw someone added diy sensors and attached to ceiling lights, with modification mosfat/on the lights pcb. Seems more complicated though
chiongkakis
Will there be significant utility usage increased? I am exploring automating my lights, ac, fan, tv for a start :)
batniss
change to a smart switch instead of a smart light. Use your app, set automation. When off, turn it back on.
My home have both smart light and switch. I regretted getting smart light. A smart switch works way smarter.
COL Juay
Apologise for more questions and clarifications.
With a smart switch and a dumb light, any chance I can control the brightness and color temp of the lights via the smart switch or app?
With a smart switch AND smart light, I can achieve both things:
1) Smart switch will be always (light will be online)
2) Smart light can be dimmed, color temp change via app or remote control or automation
What I am experimenting:
A) Getting a different brand smart switch (tuya licensed) -> i am not intending to control the smart switch, just want the always on functionality
B) Combining with a yeelight m2 pro downlight via yeelight BLE mesh hub
Hoping to achieve light ALWAYS ONLINE and light can be controlled
batniss
you don't need a smart light to control either. If you have the requirements on brightness control, color temp, with an app you will need a smart light then. Otherwise, you can pair with the right dimmer and driver but that is a separate discussion. I will suggest you get a smart light.
You cant have always-on capability when your switch can be switched off physically. Of course, you can use tapes, make your switch broken with no capability to turn it off, if you know how to wire it to keep it on despite the switch turning it off you can do that too, etc.
If you want flexibility, consider having them both SMART. Else choose which 1 is more important than the other.
i cannot say the same for you but for me i rarely play with the temp/brightness of my lights so i really don't see a need to control my lights in the fashion you just described although it is capable of doing so.
COL Juay
Got it, appreciate your response.
May I ask what lights, switches, hubs, sensors you are using? Want to have a sense of how you are doing any scheduling or automation.
DaFeiLong
Hi, I am entirely new to smart automation. I am currently planning to renovate my resale 4-room HDB flat.
I hope to be able to use a voice assistant (Alexa, Google Home, Apple Homekit) to control the lights in my house.
After reading so much on the Internet, I am still somewhat confused.
These are my current thoughts. Pls correct me if I am wrong.
1) Neutral wire should be introduced to the house so that I can avoid the problem of flickering lights or the issue where lights are switched on when the switch is off.
2) I should go for smart switches and not smart light bulbs since I don't need to control the colour of lights. It's also more cost effective. Smart light bulbs are more expensive
3) You can't mix and match products. E.g. You can't install aqara switch in the living room, tuya switch in the kitchen, Schneider switch in the bedroom. You will need 3 respective hubs to get them working.
4) To satisfy my needs, I only need a smart speaker (eg, echo dot, google nest mini, or HomePod mini), a smart hub and the relevant light switches.
The following is where I am beginning to feel confused or overwhelmed.
5) It seems that Aqara and Tuya is quite popular here.
For Aqara, I just need to purchase the following
- 1 aqara M2 hub
- D1 or H1 neutral wall switch? Why choose 1 over the other?
- If I want to have a dimmer, what should I buy?
I also read that some of you encountered problems with the setup because of firmware updates and also connection issues with Chinese servers. What can I do to avoid that?
For Tuya, I don't really know specific and reliable brands which are compatible with Tuya. Can anyone suggest the hub and switches?
6) I noticed that European brands like Philips Hue and Schneider Electric are not widely discussed here. I understand that Schneider is probably expensive. But aside from the issue with cost, are there any reasons why Schneider, a traditionally reliable brand, is not considered? If anyone used them, can you share your experiences?
7) I am concerned whether technology changes (frequent firmware updates) can cause the hubs to become obsolete. In time to come, the hub we use may no longer work. Does it mean we have to remove the switches and use a different set of products?
Sorry for the long post and thank you in advance for the replies :)
lance88
- 1 aqara M2 hub
1) I am using non neutral and my lights are not flickering, I guess really depends on what light you using, I'm using Philips lights. However neutral are important to smart switch for those higher voltage for kitchen appliances and maybe water heater. Do check on the switches specs.
2) Yes, definitely more cost effective. I just finish my Reno and if you are getting a smart switch you can exclude the one in the store room as it's kind of pointless.
3) It depends on the communication protocol like aqara maybe ZigBee but tuya is not supported so you need more hubs to support those protocols.
5) Get a global version of aqara hub. D1 is cheaper but I believe h2 allows higher voltage. Switches no issue with china version. Can't advise for dimmer. I no issue connecting aqara stuff and it's not using china as region.
DaFeiLong
Thanks for sharing your experiences, lance88. You are another happy aqara customer.
I wonder if any other experts can chime in too
batniss
all tuya. Just go any online platform google, you will get roughly the same.
Lights pair with Tuya drivers
Switch, any tuya smart switch will do.
batniss
- 1 aqara M2 hub
1. you can always go for the non-neutral capable switch
2. depends on your usage pattern.
3. you can. You either end up with multiple apps or need to learn how to sync them up effectively into say, Tuya alone, Google Home or Home Assistant etc. Most people (like myself) prefer 1 ecosystem to make it less complicated.
5. Most brands are probably the same for Tuya.
6. Price and also the ecosystem are generally i feel, more limited / way too expensive.
7. maybe. Unlikely though? Smart Switch serves as a physical switch too. It works the same regardless you pair it with an app or not.
i am not expert. I can't say i am so is only my 2cents.
DaFeiLong
Thanks, Batniss, for the reply.
Can you share the model of the hub and switch you are using?
How is your experience so far?
Do you experience flickering lights or lights that turn on although your switch is turned off?
batniss
Smatrul, Moes, zenismart, etc
excellent. I came from Livolo, followed by Aqara btw,
No. Regardless of whether i am on neutral or not. If you are on non-neutral, make sure you use the capacitor provided with the switch.
The only time it will flicker is you did not install correctly, did not use the capacitor provided or the wrong capacitor used.
shin7829
I read many info and i taobao some to try after i establish the confidence by watching youtube, chatting with suppliers, handyman.
The youtube video quite informative especially the one by alex, and MADS.
most lighting point by default will not have neutral wire. This u need to take note. If no neutral just get the non neutral smart switch.
But be careful with the wattage. They do have a min and max wattage requirement to hit.
If u only required to manual on/off light then no need smart bulb. Smart bulb is more for changing brightness and color. And on off also.
I bought aqara d1 to try. D1 is their hottest most popular switch.
Also i bought a motion sensor, and a hub, and a voice box xiaoai.
If u intend to diy.
Please ensure u do more research before trying.
Like what is neutral 零线, live 火线, switch 灯线, earth wire地线.
Whats is the meaning of short /connected? Very impt.
Whats your lamp power wattage?
Whats the intended app control? Aqara can link to google home.
Else better engage the professional to do it for u.
Chyros
Hi everyone, new to this forum and especially this thread. I’m in the midst of renovating my house and tinkering with the idea of DIY my smart home, instead of getting a vendor and just get stuff of from Taobao. I’ve heard of Orvibo smart switches and their hubs. Anyone has any recommendations? Apart from the lights, others I’d like to add to the hub are televisions, aircons, door/window sensors.
would appreciate any inputs or advises, thanks 😊
Hi guys, sorry I have another dumb question to ask. If I am pulling neutral to my smart switches, I can still use the Yeelight M2 pro with the switches seeing that it only has 2 wires.
Shadowlite
The neutral is to connect to the switches, not to the lights. So it wouldn't matter. And that's the reason why by default most buildings in Singapore don't have neutral wiring for light switches, cause it's not needed.
