wishxtreme
New to this looking to go for Aqara
Id asked for the below and non neutral, is there any 4 gang 2 way Aqara switches?
1 gang x 4
2 gang x 1
2 gang 2 way x 3
3 gang x 2
4 gang x 1
4 gang 2 way x 1
I am waiting for my Hub, H1 Pro switches (mainly 2 gangs and a few 3 gangs and dimmer) and various sensors like the smoke sensors, Zigbee curtain motors, the high sensitivity ceiling mount motion sensors. Pray hard that everything can worked well and no issues
wishxtreme
I’m currently renovating my house and looking to use Aqara devices as it’s more HomeKit compatible.
I will be using m2 hub global with d1 smart switches for all lights.
Need some advise for curtains/blinds.
- Aqara smart curtain for living room - which one shld I purchase that’s works with my hub? where shld I purchase?
- Aqara smart blinds - understood we only hav the choice of the ”add-on” that attached to the string to pull up/down. Is it strong enough? Do they hav the roller kind instead?
There are a few suppliers who carry the zigbees curtain motor and also they can customize the curtain track for you too. As for the smart blinds, the load is 40kg but not too sure it strong enough to pull wood venetian blinds.
lance88
I have aqara switches, switchbots, mi home to control lights, curtains and mi products. Others app includes kaadas for door and ecovacs for robot vaccum. Any advise on how to automate them since they are all from different apps?
Anyone have any idea on this?
flyong
I am planning my 4Rm BTO renovation, anyone can share the ballpark cost for neutral wire laying? Total switches around 20 with wall conceal type.
Any good electrician to recommend?
Thanks
shin7829
Why is there a need for pulling neutral wire?
I am using non neutral so far very stable with no issue also leh
Ok unless one need to set use smart lights. For illuminance and color adjustment
ZigguratZ
silly question, if I hook up all my smart switches via google home app .. do I need to re-sync them if my wifi is off or they will auto connect to my network?
ZigguratZ
auto connect.
Thanks, are you using google nest doorbell? does it also auto connect to the network too?
also any idea if the timed function for smart socket will works without wifi as well? Am thinking of scheduling the on and off for my router using it.
sorry for the noob questions and TIA for your advice.
batniss
with wifi? i don't think so. My router is constantly on.
COL Juay
@Shadowlite @valkyrie_angel81
Hi both,
May I ask if both of you are using the yeelight downlight M2/M2 pro? I got a few questions to ask:
1) What wall wired switches are you all pairing the downlights to (in order to keep it always online)?
2) Have you all tried to use a xiaomi gateway 3 or aqara hub (with bluetooth, zigbee) to pair?
I bought a Yeelight switch which mimics the "tic-tac" smart switch like aqara D1. It supports Xiaomi's SLISAON (Smart Lighting IS Always ON). It does NOT work when i use it on a normal/dumb light. It will always be ON, no matter how many times I switch it ON/OFF.
but it works when i paired it with the downlight m2 pro which also support SLISAON. I can use the wired switch to turn ON and OFF the downlight while it stays ONLINE on both the mi home and google home apps.
My objective is trying to save money by not using the aqara D1 switch on an already smart light while still achieving the ability to always keep the smart light "online" even when i use a physical switch to turn it off.
Any comments or suggestions from others is more than welcome!
COL Juay
Does anyone know if there's any long term issues I use a 220V 50Hz 8W light in Singapore?
I read that Singapore uses 230V.
Shadowlite
Hi both,
1) I'm using a dumb wall switch, as I didn't want to spend money rewiring the place. So I just leave it on and use automation / wireless switches to control it.
2) I'm using the Yeelight Bluetooth gateway, didn't try using other gateway.
For the SLISAON switch, think there's a small switch inside that you have to toggle between the modes I think. Saw it on the yeelight website. But I didn't get it so can't really help you with that.
wira
Anyone uses Tuya Cams ?
just wondering how is the quality and if worth to subscribe to the tuya cloud service so the cam videos can be stored in the tuya cloud.
Hi both,
Hello!
1) I bought an Aqara D1 from tabao to use with my downlights. Works with dumb and smart lights.
2) I have not but I was thinking xiaomi gateway 3 might be a good candidate if you want to use Yeelight and Aqara since it seems to be able to control both in mi app and it has both Zigbee and BT mesh. I am using Smart Things hub and Yeelight gateway. Aqara switches do not work natively in ST but can be added using device handler.
Jacqueline.
does anyone also face huge huge delay/unresponsive wireless switch with Tuya?
The issue is quite pervasive for MBR only.... i tried wireless switch and scene switch but always face huge delay or unresponsiveness (unable to turn on/off the lights) . Even if i use the smart life app, the problem persist. None of the other rooms have the same problem.
I thought it has something to do with the range of the zigbee hub so i bought another one and reconnected all zigbee main switches (with netural wire) to the new hub, but still got the same problem (have 2 zigbee hubs in total now)
The signal strength of the hub is good - what do you think i should do next? Buy a set of wifi mesh to eliminate wifi problem? any other solutions to this? TIA
