katty91
does anyone also face huge huge delay/unresponsive wireless switch with Tuya?
The issue is quite pervasive for MBR only.... i tried wireless switch and scene switch but always face huge delay or unresponsiveness (unable to turn on/off the lights) . Even if i use the smart life app, the problem persist. None of the other rooms have the same problem.
I thought it has something to do with the range of the zigbee hub so i bought another one and reconnected all zigbee main switches (with netural wire) to the new hub, but still got the same problem (have 2 zigbee hubs in total now)
The signal strength of the hub is good - what do you think i should do next? Buy a set of wifi mesh to eliminate wifi problem? any other solutions to this? TIA
I do face auto turn on issue and switched out from tuya
Alphas
Need some answers from the pros here..
Can we connect a smart switch and a dumb dimmer switch to a light? reason being i can still perform the on off with the smart switch and control the diming of the lights using the dumb switch? The light guys told me that the dimmer switch will be the master switch which you cannot turn off, if not the smart switch will not work.
Aqara smart dimmer switch is not compatible with the lights so thinking if such a setup works? If not is there any other way to do it.
Simply use a smart switch with dimmer function. Ensure the LED bulb is capable of dimming, not all LED bulb can be dimmed.
DaFeiLong
Hi, everyone.
Need some advice from the experts here.
I am currently still in planning stage for my electrical network. I am inclined to go ahead with Aqara hub and light switches. I am now considering putting in smart plugs to control hazardous electric iron or electric kettle specifically. Does anyone know if there are solutions for the aqara ecosystem? If not, what are my options? Do I have to then go to another ecosystem resulting in a aqara, tuya, <any other ecosystem>, etc?
Appreciate your kind advice.
shin7829
Oh I mean I have issue pairing mi home Xiaomi devices. And Im using m2 global
Oh I mean I have issue pairing mi home Xiaomi devices. And Im using m2 global hub
Bro why u get m2 global hub.
M2 global hub cannot work with xiaomi devices leh. M2 only got one benefit it can fire infra red to control aircon and tv and etc
Should get m1s global hub.
I now also wanna buy m1s global hub.
While my current m1s china hub van work with xiaomi and aqara with no issue.
Only cannot lonk to google nia.
Only global m1s hub can.
TanKianW
In what way is Alexa more powerful?
I find that Google Home is getting worse at recognizing our voice commands - perhaps time to try out Alexa.
No problem with mine.
Your wifi connection might be too slow/congested/overloaded.
TanKianW
I will keep the dumb switch (just on/off), use a remote dimmer switch and a dim capable smart bulb.
COL Juay
Have you tried using a xiaomi gateway 3 multi-mode hub to control both Aqara and Xiaomi devices?
That's what I am intending to test out. (purchased but stuck at china coz covid lockdown).
Evilbear
I did a DIY home automation setup at my "new" apartment few years back in 2017. (long lost thread...)
https://forums.hardwarezone.com.sg/...nce-on-smart-home-using-amazon-alexa.5785238/
I have replaced all Amazon Alexa to Google Home in 2020.
At current state, I automated my curtains, CCTVs, smart plugs, TV remotes, lights, sensors, air purifiers, ceiling fans, robo vacuum/mop, except for digi doors (for obvious security reasons). They are controlled using Google home, Philips HUE, Bond Hub, Home Assistant with Z-wave USB dongle on RaspPi/TrueNAS. On the home network infrastructure side, I am running a pfsense firewall (with VLANs segmentation) to secure my IOTs devices and 2x APs at each end of the house pushing wifi.
For starters, I recommend home owners to budget/plan out their network+security infrastructure before considering to deploy/implement extensive home automation solutions.
For home owners looking to integrate "most" of their IOTs, automation or smart devices into one single pane of GUI dashboard. You can consider deploying the open source “Home Assistant” which is an OS specifically build for home automation/smart home. Even though not all (but most) integrations could be easily configured, it could really open up endless possibilities in your DIY home automation journey (as compared to IFTTT). It Home Assistant is highly customizable and you could easily host it on a RasPi over your local network. Or even give it a DNS to access it from outside your network.​
Centrally managed IOTs over HA:
HA Integration:
Host over a RasPi4b:
*NOTE: Do consider beefing up your home network security and plan out the infrastructure when taking plunge into the DIY home automation. Interested to learn more can check out my thread here on setting up an opensource network firewall.​
https://forums.hardwarezone.com.sg/threads/starting-pfsense-for-new-users.6390714/
I saw that you have somfy RTS to zwave/zigbee module attached with an adapter. Do you still have the purchase links for it?
I really want to control those somfy blinds with my aqara cube haa
Hi everyone,
My electrician is starting on the electric works and I have some questions related to smart switches. I should be using the Aqara D1 with neutral with Yeelight M2 pro.
1. Is it possible to use 2 D1 in a 2-way switch configuration? Any additional electric works that are required or it can be configured through settings? From what I have been reading online, it seems that there are several ways to do it.
  • a) make the current 2-way switch one way by hardwiring it closed on one side and use the Aqara wireless switch in place on the side that is hardwired.
  • b) wire the switch in this configuration:
    Switch 1 - wire L, L1 and L2
    Switch 2 - wire N & L and use as a wireless switch
2. I understand that in order for the smart light to always be powered on, the smart switch has to be always in an on state. From what I gathered, I have to set the switch to wireless mode and use routines to set it to turn on/off the smart lights using the light switch button. TLDR I would like to have power always on but I would also like the physical experience of switching on and off light.
TanKianW
Hi Alex, came across your Youtube video a while back. Haha. Realised you given HA a 4.5/5 for difficulty in setting up.....well, have to agree with that. It is not for everyone.
I am not using the somfy RTS to zwave module anymore. I have streamlined the curtain remote to my Bond Hub and control over HA/Google Home.​
Evilbear
wow I didn't know that bond supports somfy RTS, that is going to be a much better device vs broadlink, of course you pay a higher price. But it's still much cheaper than getting the RTS to zwave module. It's perfect for me since Bond is also natively integrated to SmartThings, time to get it!
TanKianW
If you are also using ceiling fans (with remote contol), Bond could likely control it. It could pretty much cover the function of RF and IR devices (could be through learning) while connected over wifi to your smarthome supervisor (SmartThing/HA).​
ferbulous
Hi everyone,
1. Is it possible to use 2 D1 in a 2 way switch configuration? Any additional electric works that is required or it can be configured through settings? From what I have been reading online, it seems that there are several way to do it.
  • make the current 2 way switch one way by hardwiring it closed on one side and use the Aqara wireless switch in place on the side that is hardwired.
  • Switch 1 - wire L, L1 and L2. switch 2 - wire N & L and use as a wireless switch
2. In order for the smart light to always be powered on, the smart switch have to be always in an on mode. I need some advice on how to set it such that it is always powered on but yet can still turn the smart light on/off by pressing on it. From what I gathered, I have to set the switch to wireless mode and use routines to set it to turn on/off the smart lights using the light switch button. Any other way to go about this? Checking on this cause I am wondering if I can use Tuya lights with Aqara switches. TLDR I would like to have power always on but I would also like the physical experience of switching on and off light.
Easy way,
Set some automation where the switch will always turn on if someone toggles it off as and using wireless switch as you mentioned
Possible issue with this?
Might reset the wifi/zigbee bulbs if toggled on/off repeatedly or too quickly (especially from family members
The not so easy way
TASMOTA
tldr - gpio pin for relay switch to smart bulbs always set to on, using tasmota group magic can tie button switch directy to bulbs without any smart hub as middleman
TanKianW
Hi everyone,
I will suggest keeping the hard switches intact. Several smart homes I work or do consult with, will have faulty smart switches after a while (after 2 years or less), subjected to the build quality, and it could be a hassle to maintain and replace, especially for home owners. With exception that the lighting design you using are very exclusive or closed system, then a smart switch might actually be the solution.
As for how to always keep it on? This is as easy as just leaving it on and only use a remote switch (by the side) to switch it on/off. After a while, everyone in the house will grow accustomed to it, and your worries will solve on its own. Locations like front door, toilet and hallway, can use sensors to turn them on/off. You can choose a sensor that includes illumination and motion sensors which turn off during the day when the ambience lighting is bright enough, but turn on in the night while detecting motion when a family member making their way to the washroom in the middle of the night. This is especially useful for families with old folks/kids, like mine. The best configured and deployed home automation flows smoothly with your daily lifestyle without causing much hassle or disruptions. Or better, it becomes so natural, you did not even notice it.
Just sharing. I am using the full suite of Philips Hue, sensors, hub and lightings, quite an early adopter too. The initial cost is higher but it will be better for the long run (>5 years now for me, only 1 burnt out bulb to this day). Philips HUE ecosystem API is very workable, and could be easily integrated with any smarthome supervisor (Eg. OpenHAB, HA) for future automation. You can look for them on Taobao too, which usually much cheaper. As for switches, I kept the hard switches intact but changed them to nicer designs from Legrand/Schneider.​
Alphas
There are also self-powered smart switches that do *not* require any wiring (not even live) to the switch. Basically it sent a RF signal to toggle a smart receiver as a switch. It also means the switch can be placed anywhere in the house, no cabling required. I did post it sometime back, some requires a small coin battery, while there are also kinetic switches that do not even require battery.
https://www.aliexpress.com/item/4001095272467.html?
No cabling, no battery, smart switch
https://www.aliexpress.com/item/1005002885325033.html?
Easy way,
Thanks @ferbulous! I am pretty noob to wiring and electric works so I will opt for the easy way.
Sorry if I bombard you with more questions, would your recommendation apply to my scenario of 2-way switches?
Haha getting more confused. I suppose the really easy way is to terminate the 2 way switch into 1 way. May I know if this is a complicated process?
ferbulous
Same, i just know the basics, always turn off breaker before you change anything
Not too sure about aqara d1 in 2 way setup, technically it could work if you setup automation where d1 a will toggle d1 b and vice versa. Which is just same method using wireless switch
Seems like aqara t1 might suit you better
For me, I just use this sonoff module (with 3 wire option) so I can install to my existing 2 way switch without additional cable. Check the installation diagram to see which one suits better for your home
