COL Juay
Xiaomi can add many devices together. Just change to china mainland and u can choose to bind aqara even ecovacs also have.
Want to ask, if choose china mainland, can google home still sync and see the devices in china?
i tried to change between Singapore and China server in mi home app, but when i put China server, the devices i added in mi home cannot be seen in google home anymore. Quite perplex and frustrated cause China server got alot more options.
any suggestions? do you use google home to control china server mi home app devices?
shin7829
Does anyone know if there's any long term issues I use a 220V 50Hz 8W light in Singapore?
I read that Singapore uses 230V.
I thought sg is using 220 to 240?
I actually wanted to try with google assistant. Yes i am aware of once it mihome change to mijia a whole lot of options open up.
Iits a pity i dont have google assistant to try. I am worrying google home can only allow mihome and not mijia. Then it may pose abit of problem.....
Come worse case all my devices will activate via mijia voice box.....
batniss
Anyone uses Tuya Cams ?
just wondering how is the quality and if worth to subscribe to the tuya cloud service so the cam videos can be stored in the tuya cloud.
i always wanted to try but didn't. If you do, do share your feedback!
batniss
does anyone also face huge huge delay/unresponsive wireless switch with Tuya?
The issue is quite pervasive for MBR only.... i tried wireless switch and scene switch but always face huge delay or unresponsiveness (unable to turn on/off the lights) . Even if i use the smart life app, the problem persist. None of the other rooms have the same problem.
I thought it has something to do with the range of the zigbee hub so i bought another one and reconnected all zigbee main switches (with netural wire) to the new hub, but still got the same problem (have 2 zigbee hubs in total now)
The signal strength of the hub is good - what do you think i should do next? Buy a set of wifi mesh to eliminate wifi problem? any other solutions to this? TIA
i never get the scene switch so couldn't comment.
I am using the RF switch though... no lag.
COL Juay
I asked an electrician, he also confirmed 220-240V in SG is safe. Thanks!
Google voice assistant works on iphone or android phone as well. just need to install Google Home app. No need to have the physical google home mini speakers to try.
it's a problem some devices just show on Google Home, some just dun. I am buying a list of devices to try it out, if can work, if cant work need to refund or sell on carousell already :(
Wall Switches:
1) Yeelight FLEX wall switch (wired) - does not connect to app (no BT or zigbee) but good as a semi-smart switch to control SLISAON yeelight devices.
2) Xiaomi mijia smart wall switch - works on BLE instead of Aqara's D1's zigbee (waiting to test on SG server)
3) Aqara D1 non-neutral switch - waiting to test on SG server
Wireless mini switches:
4) Yeelight wireless switch key (like small button) - does NOT work in Singapore server and cant see in Google Home
5) Aqara smart wireless mini switch - waiting to test on SG server
Hubs:
6) Yeelight mesh BLE hub - works on SG server (bought from China global set with EU plug)
7) Xiaomi gateway 3 multi-mode hub - hoping it can replace yeelight mesh ble hub and also control aqara zigbee devices (waiting to receive and test), then no need a separate aqara hub (m2 / e1)
Sensors:
8) Motion sensors - from both Xiaomi and Aqara (waiting to test on SG server)
9) Door sensors - from both Xiaomi and Aqara (waiting to test on SG server)
Lights:
10) Yeelight M2 pro downlight - tested to work well on SG server and Google home
11) Yeelight LED strip - going to buy to test on SG server
12) Yeelight 32cm ceiling light - 32W - going to buy to test on SG server
Others:
13) Aqara magic cube - testing if it works on SG server
14) Yeelight BT remote for ceiling lights and LED strip - does not work with yeelight downlights, no ceiling / LED strip to test yet
wacko
storm913
Hi, anyone has the knowledge to help me here. I have installed my Moes Zigbee smart switches (Without Neutral) to majority of my home switch and faces these issues:
1. 2 gang switch for my kitchen (1 for kitchen light, 1 for service yard laundry rack), about 30% - 40% of the time i do an action on the laundry rack (lower rack, raise rack), there is a chance that my other lights will flicker. These other lights are kitchen light as well as my corridor lights and toilet lights (I suspect they all use the same Live Wire and hence affected together.) Is there a way to fix this or my laundry rack is not suitable to have a smart switch installed?
2. Another issue I have is the pre-installed HDB BTO 2 way, 2 gang switches for my dining table light. This dining table light can be originally controlled at my home door way as well as the corridor area. At the doorway area, there is no problem as there is only 1 live wire. But at the corridor area, the 2 way, 2 gang switch comes with 2 live wires. (In the 2 gang, there is one to control the dining light which i think uses a different live wire to the other gang) The Moes smart switch only comes with 1 Live wire input, does this mean it is not suitable?
Note: For now, I have connected the dining light cable and did not attach to the smart switch, so it becomes a permanently connected on the corridor end.
3. Last issue i face is the compatibility with google home. After syncing to Smart Life app, i link it to google home and I noticed duplicate device in the google home app and they are often unresponsive in the google home app. Hence using the google home app or using the voice command will not work majority of the time. Have to rely back on the smart things app.
Thanks for any advice on the above!
batniss
1. it depends. The Amp used on your laundry rack, how the wiring etc. I am using a smart switch and have no issue on my laundry rack.
2. The easiest will be just use the app to programme it to make it 2 way.
3. i am using Tuya instead. No issue though.
storm913
1. Any idea the max Amp that my smart switch can take? I'm using Orlant X5S. Will have to figure a way to stop the flickering and unsure if there is any safety issue.
2. Yup, will try to programme the empty gang switch to programme it, just considering if there is a better way than my current approach.
Thanks for the replies.
batniss
1. it depends on your Smart Switch. Moes has 10A all the way to 20A switches. Your Orlant X5S has a rated 900W.
2. I feel what i said is the best and safest for any home users. There are other methods though, get a relay, put both L into 1 (if you don't know what you are doing, i will suggest engaging a trained electrician instead), etc.
shin7829
Wall Switches:
Hubs:
Sensors:
Lights:
Others:
Wow then i go try on hp app liao
shin7829
Wall Switches:
Hubs:
Sensors:
Lights:
Others:
I have tried all the below with success.
Using aqara m1s hub, 2 gang non neutral d1 switch, xiao ai/xiao mi voice box, aqara motion sensor. All from taobao cause cheaper.
Note all app must be set as mainland china settings.
1. Bind with Xiaomi app to link with the all aqara items
And remote control switch from phone.
2. Bind with Aqara app to link with aqara items
3. Bind with xiao ai/xiaomi app. Voice activation on xiao ai/xiaomi voice box to turn on/off switch.
4. Using scene control with motion sensor to turn on/off switch
Now i have problem. I try link with google. Its not possible.
I suspect is the hub issue. Cause my hub it dont allow to be added unless setting is switch to china mainland.
I also try when i change the aqara setting to non mainland china, google voice assistant and alexa starts appearing instead of xiaoai xiaomi voice box.
Thus, i am under the impression that if my hub is global one, perhaps i can link and make it all work with google/alexa
Wondering if anyone here able to share the experiences or can tloan me an aqara hub which was bought in lazada and certified to work with google and alexa.
It will be better if able to tloan the m2 aqara if possible
Come worse case i may just stay with xiaomi. The programming and interface of xiaomi is really nice.
Please do pm me if really can.
ferbulous
In what way is Alexa more powerful?
I find that Google Home is getting worse at recognizing our voice commands - perhaps time to try out Alexa.
Honestly I’m just using alexa because i can use other wake word, like ‘computer’. Which is something that google should add as well
TanKianW
I did a DIY home automation setup at my "new" apartment few years back in 2017. (long lost thread...)
https://forums.hardwarezone.com.sg/...nce-on-smart-home-using-amazon-alexa.5785238/
I have replaced all Amazon Alexa to Google Home in 2020.
At current state, I automated my curtains, CCTVs, smart plugs, TV remotes, lights, sensors, air purifiers, ceiling fans, robo vacuum/mop, except for digi doors (for obvious security reasons). They are controlled using Google home, Philips HUE, Bond Hub, Home Assistant with Z-wave USB dongle on RaspPi/TrueNAS. On the home network infrastructure side, I am running a pfsense firewall (with VLANs segmentation) to secure my IOTs devices and 2x APs at each end of the house pushing wifi.
For starters, I recommend home owners to budget/plan out their network+security infrastructure before considering to deploy/implement extensive home automation solutions.
For home owners looking to integrate "most" of their IOTs, automation or smart devices into one single pane of GUI dashboard. You can consider deploying the open source “Home Assistant” which is an OS specifically build for home automation/smart home. Even though not all (but most) integrations could be easily configured, it could really open up endless possibilities in your DIY home automation journey (as compared to IFTTT). It Home Assistant is highly customizable and you could easily host it on a RasPi over your local network. Or even give it a DNS to access it from outside your network.​
Centrally managed IOTs over HA:
HA Integration:
Host over a RasPi4b:
*NOTE: Do consider beefing up your home network security and plan out the infrastructure when taking plunge into the DIY home automation. Interested to learn more can check out my thread here on setting up an opensource network firewall.​
https://forums.hardwarezone.com.sg/threads/starting-pfsense-for-new-users.6390714/
wishxtreme
Need some answers from the pros here..
Can we connect a smart switch and a dumb dimmer switch to a light? reason being i can still perform the on off with the smart switch and control the diming of the lights using the dumb switch? The light guys told me that the dimmer switch will be the master switch which you cannot turn off, if not the smart switch will not work.
Aqara smart dimmer switch is not compatible with the lights so thinking if such a setup works? If not is there any other way to do it.
shin7829
Why not just change the bulb to a smart bulb while keeping your smart switch then.
lance88
I tried pairing Google home to aqara -others and Mi home, aqara works well showing all devices but for Xiaomi devices under Mi home, there is no webcam and the fans seems to be limited at just on and off button. Anyone faced the same issue? My Mi home is set to Singapore region
katty91
I tried pairing Google home to aqara -others and Xiaomi, aqara works well showing all devices but for Xiaomi I didn't managed to get any webcam and the fans seems to be limited at just on and off button. Anyone faced the same issue? My Xiaomi is set to Singapore region
Need m1s global.. only aqara hub showing in the list under mi home Singapore. Seems to be sold out everywhere
