Mijia is mihome app
Mihome is mijia app
Mijia = Mihome = xiaomi
Mijia is when mihome app set to china settings.
Mihome is when mihome app set to singapore settings.
Under different setting different equipment will appear. By default, when mijia is used all things will appear.
But when mihome is set, only certain equipment will appear.
At this moment mijia is very powerful and interface also very friendly.
Mijia also can link with tuya, and aqara
But mijia cannot link with google.
Only mihome can link with google.
Sibeh confusing leh.
Also since i have both global m1s and china m1s hub. I manage to do some interesting testing.
When global m1s hub is used. China bought aqara stuffs also can be added as long as it appear in the aqara app under location as others settings. U no need to buy the what nonsense crap of those label global neutral or non neutral d1 switch or global sensor. China stuffs work as fine.
And when the location of aqara is set to non china, example others. Google and alexa appear.
As such if your aqara app is not china mainland as location setting. It can now be bind with google home and alexa liao
As long as we share more indepth knowledge those stuffs outside or smart company cant mark up obscenely. And the more we can spend wisely.
Now i trying to see which aqara curtain is actually the so called global version of china version. As long as i can tally them, getting the china version should be able to add into aqara under others setting. Then this will allow the same Google to be link with this device.
China aqara curtain rail approx 180sgd. The so called global aqara curtain cost near 360. Thats 2 times the cost. And this exclude installation. Jeez
If you refer Mijia as china set region of mihome and mihome as Singapore set region. Then yes, mihome can link with Google home. I remember previous post someone mentioned Mijia cannot link with Google home.
Eventually the aim is to combined all into one app. So if you want go for china regional setting and forego google home, you need to have all the stuff from aqara and Xiaomi. Apparently robot vacuum is not Xiaomi strong suit, unless roborock series can be paired.
Google home has it's limits, for example you can't see your robot vaccum mapping nor any webcam's function (if anyone can do it, do let me know what did you get?)
Only the hubs need to be global version to work, switches itself can be direct from China.
As for curtain, I went with the path of Ikea and switchbot. Now I'm kind of regretted. I can't get it to work as it should all the time. After some time the bot will go off it marks, like maybe too left or too right and it will mess up eventually (maybe it's the rod issue, if using tracks then maybe it works well). Would love to hear input from those of you that tried it.
