shin7829
I trying to create automation routine in google home.
The first language is set to chinese.
Second language as engliah
Why so
Then i use handphone google voice assistant, But even though i said the correct phrase, it dont execute the action command.
gumzgumz
Would like to ask if track lighting is compatible with WiFi no neutral smart switches. If so, where would the capacitor be installed?
batniss
same, based on your wiring. You only need 1 (usually for tracks). Just connect in between the switch and the light will do.
wacko
this is not how you wire a capacitor in a no-neutral smart switch circuit. the capacitor has to be wired across the light itself (the L1 light if it's a multi-gang switch).
batniss
In my track setup, I only have 1 input regardless of the number of lights. You attached the capacitor to the track accordingly.
nevertheless, mine works. I am not sure to which kind of track you are referring... In a light only setup, what you said is accurate which I have posted the same in many posts back before.
wacko
hmmm, care to share why a track light can have the capacitor wired differently? to me a track light is just a lighting device with multiple bulbs.
batniss
My track only has 1 electrical input. You can treat that as your L1. At least that's how mine work. - mine is those magnetic types, plug the light like a socket and it will turn on. No additional cabling is required. So far it is working fine with no flickers etc, so i believe i have it set up properly,
If yours has individual cabling, then it is vastly different from mine then yes, you may need to hunt whichever is your L1 in the strip and install the capacitor accordingly.
i am no electrician. If you are unsure, will advise getting a proper electrician to handle it for you.
hotchoco1ate
Hi, am in the midst of my renovation and my wiring is already done. Am looking for a dimmer switch to use with my Sol Luminaire lights (all dimmable). Have bought a bunch of Aqara D1 switches and have shortlisted the Koble Smart dimmer switch (slide up and down to dim) as the dimmer. So here’s my question:
- is there a way to wire both the Aqara and Koble switch together, such that I only need to set the Dim setting once on the Koble, and then whenever I switch on and off the Aqara D1, it wil “remember” the dimness setting? I don’t intend to use the on/off function on the Koble since the Aqara can do that. I’m concerned because both are smart switches, and am not sure if the Koble can be configured such that i only use the dimming function and ignore its on/off function.
- Also, is there a way to configure such that if Aqara is set as the main switch to my lights in the room, then I can still control the on/off function via the Aqara app?
wishxtreme
I have explored some option and in the end, for those lights that are dimmable i will be using Lutron smart switches to control on, off and dimming while connected to my Homekit for scene automation with my other Aqara sensors and products. As for the rest of the lights that do not require dimming, i am using the Aqara H1 for them.
I did ask some shops about wiring a dumb dimmer switch with Aqara smart switches. It seems like it cannot be done. Not sure about if both are smart switches.
Hope yours will work.
batniss
it is on the driver, right? If the driver "remembers" it, the switch is just a means to switch it on/off?
At least mine works that way.
gumzgumz
Thanks. I think the explanation makes sense since the track is connected to L1 hence capacitor is fitted on wiring to the track and not on the track light itself. The number of lights on the track itself doesn't matter since all connected to the track
batniss
hope it helps.
I did a lot of the electrical work by myself hence. I am pretty sure what I said is what was done however there are probably a billion variants out there so we cannot discount everything out and put a claim citing no, only mine works. :)
zenify.me
Not sure if this is the right place to ask but does anyone here has experience with installing smart doorbells at HDB? Is it mandatory for approval to be obtained from town council or a gray area since it's technically not a CCTV...
lance88
If your neighbor is directly opposite of your door, you can consider stacking some layers on the top of the cam so it become tilted down and does not record your neighbor door or doorstep.
VodkaPear
Any motorised blind to introduce? I using Aqara for my curtain, light switches, camera and etc. I prefer blinds for the 3 bedrooms. So looking for something which can work with my hub.
TrueBeliever_jh
Nice, I am getting magnetic track lights for my place too. Are your magnetic track lights smart?
VodkaPear
COL Juay
What are magnetic track lights? just curious, are your lights GU10, smart or normal? can share any good lobangs on track lights as well?
i'm considering should i buy track light on taobao since it is so much cheaper. considering those 1 piece solution with non-removeable lights on a track and an led light as well. (hopefully you understand my description, if not i can share a taobao/shopee link.
