batniss
Nice, I am getting magnetic track lights for my place too. Are your magnetic track lights smart?
The drivers, yes. In other words, my tuya driver determine what light color the lights should show when it is on.
But for my use case, actually, i feel it is useless. I controlled more with my switches than lights. YMMV.
I also installed for my friends with E27 bulbs on a track. His track is dumb, his lights are Tuya (individually). it works too.
COL Juay
I asked an electrician, he also confirmed 220-240V in SG is safe. Thanks!
Google voice assistant works on iphone or android phone as well. just need to install Google Home app. No need to have the physical google home mini speakers to try.
it's a problem some devices just show on Google Home, some just dun. I am buying a list of devices to try it out, if can work, if cant work need to refund or sell on carousell already :(
Wall Switches:
1) Yeelight FLEX wall switch (wired) - does not connect to app (no BT or zigbee) but good as a semi-smart switch to control SLISAON yeelight devices.
2) Xiaomi mijia smart wall switch - works on BLE instead of Aqara's D1's zigbee (waiting to test on SG server)
3) Aqara D1 non-neutral switch - waiting to test on SG server
Wireless mini switches:
4) Yeelight wireless switch key (like small button) - does NOT work in Singapore server and cant see in Google Home
5) Aqara smart wireless mini switch - waiting to test on SG server
Hubs:
6) Yeelight mesh BLE hub - works on SG server (bought from China global set with EU plug)
7) Xiaomi gateway 3 multi-mode hub - hoping it can replace yeelight mesh ble hub and also control aqara zigbee devices (waiting to receive and test), then no need a separate aqara hub (m2 / e1)
Sensors:
8) Motion sensors - from both Xiaomi and Aqara (waiting to test on SG server)
9) Door sensors - from both Xiaomi and Aqara (waiting to test on SG server)
Lights:
10) Yeelight M2 pro downlight - tested to work well on SG server and Google home
11) Yeelight LED strip - going to buy to test on SG server
12) Yeelight 32cm ceiling light - 32W - going to buy to test on SG server
Others:
13) Aqara magic cube - testing if it works on SG server
14) Yeelight BT remote for ceiling lights and LED strip - does not work with yeelight downlights, no ceiling / LED strip to test yet
For anyone that might be interested,
7) Xiaomi gateway 3 multi-mode hub - can connect on SG server with aqara motion sensor and aqara door/window sensor via zigbee 3.0. high chance there's no need to purchase a separate aqara hub. assuming this will work with yeelight downlight m2 pro via BLE mesh too.
shin7829
Question.
I have aqara hub global.
My aqara app is link to google home
My google is unable to link with tuya app
Can i add tuya devices by using aqara hub?
Then only it can link with google home?
Or i will need another tuya hub again just to add tuya thingy?
What are magnetic track lights? just curious, are your lights GU10, smart or normal? can share any good lobangs on track lights as well?
The tracks are magnetic so you can plug and play flood, spot, accent, pendant etc. You can take a look at Klite Concept. You can take a look at Klite concept who has the product on their website. If you are interested, pm me for contact.
Haha ya, mine is Tuya enabled too. You are right that except for the changing of color and to set scenes there after, it might not be really useful.
Yeelight pro series have magnetic track light now too but tbh tuya is ok too.
ferbulous
Any zemismart homekit hub user here?
Anyone tried pairing with tuya zigbee lock if it does work in homekit?
ferbulous
https://www.zemismart.com/collections/device-work-with-zmhk-01Based on this list on their website, it should work
Thanks, just asked zemismart also, they did say it will work.
Just need to find the zigbee lock with a matching single latch deadbolt type for my doors.
I see most tuya wifi ones got that type but i haven’t spot the zigbee yet
Been hesitant to get the tuya lock, while they work great ( a friend of mine using one for 2 years) & cheaper price. There’s just not much progress with lock integration on tuya homeassistant integration since tuya team took over 🤔
wira
For aircons i suggest invest more and buy a sensibo device to manage your aircon. I was using an ir blaster before switching over to sensibo as turning on and off the aircon alone is not sufficient. You will want to adjust settings depending on the weather outside. Fiddling with the aircon remote in the middle of darkness is impossible and turning on the light hurts the eyes and disturbs your partner in bed.
Sensibo allows you to manage all the functions of your remote with your phone and with its built-in temperature and humidity sensor, you can configure it to adjust your aircon settings automatically depending on the changing room temperature.
I now have a sensibo in every room of my house.
Posted from PCWX using SM-G988B
just got the sensibo as well. works very well compared to normal ir blaster.
but i am still trying how to set the Climate react. anyone knows how to set it ?
Qn : If i set it to when temp goes below 24 deg, to set AC to Fan mode only. so when the temp goes back up to above 24 deg, what will happen ?
Do i also need to set the trigger when temp goes above 24 Degree ?
i only want this to be active when i turn on the AC. realised when i set climate react settings it is automatically active and will auto turn on if i set the trigger based on temp above 24 degrees
katty91
just got my hands on the aqara a100 doorlock from Shopee after waiting for close to a month.. thank u Alex for the review on YouTube altho it was ranked no 2, but the apple key sealed it for me as the entire household use iPhone.
waiting for installer to come set it up
VodkaPear
for gate are u using any locks?
lance88
Personally, if you want to save money, lock better to be installed on gate only. Quite a few house I came across need the main door to be open for the house to be windy.
