sequalancer
Be it m1s, m2, e1 hub or the g2h camera hub. Make sure seller is selling global version.
Aqara switches are perfect never had any issues and easy to do automation within the app. H1 is more responsive and build is more premium
Hi, I've read up quite a bit and I'm pondering which version of Aqara switch(wired) I should get since they have E1, D1, T1 and H1. Also whether I should get the 1 with neutral? 😐
HelIoo
Do all brands of motion sensor requires to buy their hub to work with their other devices? For example switchbot motion sensor requires to buy their switchbot hub to work with Switchbot bot. Is there such motion sensor that use wifi and dont need hub?
Alphas
Of course there are motion sensors that do not required any hub. Just search for those tuya/smartlife sensors without zigbee or aqara hub. One example is here.
Tuya/Smartlife motion sensor
batniss
I wouldn't recommend sensors to work directly with WIFI. It is slow. Unless u can take 2~4s latency before it triggers.
sequalancer
hi, does anyone know which version of Aqara switch is the newest and most stable? I would like to avoid getting 1 with connection issues. thank you
COL Juay
I am getting a E1 to compare to D1 to determine which to get. Kinda of dislike the mushiness of D1 and hoping E1 is better in terms of the tactile feedback.
To me, H1 is extremely overpriced, so I will not consider.
T1 is a bit too much hassle for me. prefer to have a rocker switch + module all-in-one rather than rocker switch and module separately. (Not super sure about advantage of T1 though).
Earthling
Does anyone know if Broadlink RM Pro 4 can do the following things? Basically i want it to change my starmex aircon to Fan mode at 7am everyday then turn off 1 hour later. Is it do-able with the app ? or can only set it to on and off?
Somangel
Hi everyone. I have some qns on Aqara and Xiao mi Mi Home app hoping to look for advice from the experts here:
1) is Aqara G2 Camera hub global version able to be paired to Mi Home app using China server?
2) if #1 is possible, does it mean I can also add child devices like Aqara smart switches which can be global or China versions to mi home (on China server) through the Aqara G2 hub?
3) if #2 is also possible, can the devices work with Google home through Mi home app? (I know these devices will work w Google Home if they are through Aqara app).
Sorry if this has been asked before as I can’t seem to find an answer in searching through the thread.
I have Xiaomi devices which only works on Mi Home China server and was hoping to set up automations with Aqara child devices like D1/H1 (EU) smart switches paired to the G2 global hub. Hence trying to see if the above is possible.
I made a post earlier about my testing experience, you can search for it on this thread.
In brief, I bought a xiaomi gateway 3 on shopee, came with a EU plug instead of China, so I assume it's global version. Priced reasonably. One hub settle everything instead of needing aqara + xiaomi hubs. Save a few $$ too.
Hi @COL Juay nice. I made the mistake of getting an Aqara M2 which couldn't be added to Mi home (SG Server). Failing which I got a M1S which can be added but I couldn't pair add any D1 in the Mi home app. The first instance was due to my blunder as I did not read which hubs are supported but on the bright side I have an IR blaster to play with.
You manage to add all your D1s to Mi home (SG Server) using the xiaomi gateway 3 right? Can share which seller you bought from?
ccmheoa
Yes can set timer to perform such actions.
Eg
timer1 set to fan mode, timer 2 set to off
COL Juay
https://s.lazada.sg/s.05Rka
this is the seller i bought from. I dun think he is the only one selling this version. Doubt there's any difference between the numerous sellers on lazada/shopee.
Take note, aqara D1 switch pairing to xiami gateway 3 is not "officially" supported (meaning it will not appear automatically like those officially supported devices once power on).
I got it to work by "bluffing" the mi home app that I am pairing another device in the list such as, Mi Wireless Switch. It's a trial and error that it managed to work, but I can un-pair and re-pair and it still works, so I guess it should not be one time lucky only.
In fact, I paired my aqara motion sensor, aqara magic cube, aqara window/door sensor, aqara mini switch all via this "bluff" method. As long you can get the child device to go into pairing mode, then you can trick the mi home app to let you pair to mi home gateway 3 already.
Btw, I am waiting for Aqara E1 switch to arrive from taobao. I bought E1 because I am not satisfied with the tactile feedback of my D1 switch. (duno is my D1 switch button faulty though)
COL Juay
Anyone knows how to link / connect / sync between Yeelight and Mi home app (both SG server)? I am hoping that mi home can add the devices from my yeelight app. Without adding to mi home app, I am unable to use my sensors / scenes to control my led strip :(
Background:
I bought the yeelight light strip from taobao (it's called willow light strip). the model number is identical to what is sold locally. I am able to pair to yeelight (SG server) but mi home app can see the willow light strip but indicates it is only supported in China. No matter what I try, (connecting my phone to the light strip wifi), it refuses to connect to mi home app.
Side note: it works perfectly well in google home app. Google home is linked to both Yeelight and Mi home app.
@COL Juay Cool! Thanks for replying, I ordered one to play with. Does yours come in Chinese packaging?
I got some YeeLight M2Pro downlights (from Taobao) and managed to add them to the MiHome app. I can control them with the Mi Home app.
COL Juay
Mi home gateway 3 comes with packaging is in english. Cant recall the instructions is in english or mandarin but it works, why bother?
My M2 Pro works well, it is just the LED strip (willow light strip). The local distributor for yeelight also confirm with me, it can only connect to yeelight app (regardless it's SG or China server) but NOT the mi home app (SG server)
koohansen
Hi,
I have a mix of hardware, some given, some leftover from previous projects.
1. Aqara M2 Hub
2. Aqara D1/H1 switches
3. Aqara Cube, Motion Sensors
4. Smart Things
I plan to install Aqara A100 Smart Lock, but i plan to mix some Zigbee sensors, such as Smartul Smart PLug with metering, can those be detected under M2 hub? or should i get Tuya hub>?
I wish to control all the devices in a single app if possible
