yamashita
Moderator
Moderator
Mushroom themed Dashboard for Home Assistant (HA) smart home integration
Current smarthome Integration list:
  • Philips Hue (all lights)
  • pfsense firewall
  • Ruckus Unleashed (Access points)
  • TrueNAS storage (Plex servers & VMs)
  • Arlo CCTVs
  • Bond hub for RF ceiling fans/lights and Somfy curtains
  • Zigbee/Z-wave modules
  • Logitech Harmony remote
  • Haiku/Big-ass ceiling fans
  • Dyson fans and cloud
  • Ambiclimate/Sensibo A/C smart control
  • Google Home Display
  • Sonos speakers
  • Nvidia Shield
  • Deebot and Braava jet robo cleaners
  • Track every single home mobile devices
  • Track battery life/motion/light sensors of every remote controls/sensor
Adding custom configuration to count the "lights on", track the owners at home, custom greeting messages and active CCTVs:
Click into the individual custom room "button"
CCTVs integration:
Using your old ipad as a control dashboard at your tv console or even wall mount it.
You could use an intel M6 mini cube pc to run the HA operating system and supervisor, and attach zigbee/zwave module using the USB.
Mushroom is a godsend for dashboard creation. There's a recent Youtube tutorial video on it and it's helpful for the uninitiated.
I am running mine on Raspberry Pi 4.
ferbulous
  • pfsense firewall
  • Arlo CCTVs
  • Sonos speakers
  • Nvidia Shield
CCTVs integration:
Hi bro, do you use ifan03 for the fan control?
Do you have slow speed with speed 1 & 2 like some other people complained
https://support.itead.cc/support/discussions/topics/11000031823
TanKianW
ferbulous
Nope. I use Bond Hub to control my ceiling fans/lights (Elmark).
My other fans are controlled using wifi (Dyson and Haiku) which is supported by official HA or HACS.
Oh those are some ultra premium pricing brands that i probably won’t get anytime soon
As for the other ir controlled fan, do you use some kind esphome ir receiver/script combo to get ir feedback to ha (for current fan on//off/speed status) or it’s just one way command?
TanKianW
My Bond hub can be used to control my RF and IR devices (including IR fans and RF curtains). So I do not use the kind you listed.
You can have a look here. Someone recommended using ESPHome in the community forum too:
https://community.home-assistant.io/t/using-home-assistant-with-ir-controlled-devices/375137​
Evilbear
  • pfsense firewall
  • Arlo CCTVs
  • Sonos speakers
  • Nvidia Shield
CCTVs integration:
I am going to get the Home Assistant Yellow to start with 🤓
https://www.crowdsupply.com/nabu-casa/home-assistant-yellowHere are some of my new toys that I am going to add in my setup:
- bond hub (thanks to your intro)
- aqara P1 motion sensor
- aqara fp1 presence detection sensor
- Lytmi neo sync box
ferbulous
I meant in terms of getting feedback status on the ir controlled devices.
Let’s say initially you had the fan speed on speed 4 by changing in ha, then later someone use physical remote to change to speed 2.
Does that speed fan get updated in ha?
TanKianW
Currently, the wait for securing the HA Yellow (on RasPi CM4) might take quite some time during this chip shortage period and the absurd street price on a RasPi 4 or CM may hinder its production.
Most will start with a RasPi, including me (started with a RasPi 3-4 years ago). But after a while, most DIY home automation enthusiasts will outgrow it very soon.....including me. A low powered mini x86-64 hardware or a VM running docker containers might be a better alternative.
Feel free to check out these alternatives (videos) too.​
TanKianW
I have never tried that. But logically (I could be wrong), If I want to achieve what you had in mind, I will probably need to run a IR receiver (send/receive feedback to HA), with some form of MQTT broker and custom script/config to make it work with HA. Another problem I see here is, you will probably need the receiver (within range/line of sight) to be able to catch the IR signal when you use the physical remote.
Using the IR blaster function on my Bond hub, it does not get updated under the scenario you described. I can only get it to on/off and increase/decrease speed on a legacy IR remote controlled KDK wall fan.​
TanKianW
**For More Advanced Users: Remote Accessing your HA using DuckDNS and ACME Certs**
Alternatively, you could access HA over VPN (Eg. Wireguard/OpenVPN) or spin up a proxy server with TLS/SSL certificates to access over https using a more advanced network firewall solution like pfsense. For anything with remote access,
NOTE: I will recommend setting up 2FA log in for your HA and set up a properly configured VLAN to separate the internal/external LAN network just in case it was compromised.
VPN setup on pfsense:​
https://forums.hardwarezone.com.sg/threads/starting-pfsense-for-new-users.6390714/#post-130207493
HAproxy on pfsense:
https://forums.hardwarezone.com.sg/threads/starting-pfsense-for-new-users.6390714/#post-130207504
Eg. Access your Home Assistant (HA) externally (.....even on your car's HUD)
katty91
hi,
anyone bought stuff from this website ?
https://www.smart-home.com.sg/eureka-mono-switch
as per previously mentioned, bought some broadlink switches and they sucked so need some advice for brands to recommend and prefer that they also provide installation services,
thanks in advance
are these running on tuya if yes u should avoid.
flickering issues and auto on in the middle of nowhere. aqara doesn’t have all these issues.
batniss
i am using Tuya. I beg to differ to what you have claimed. Only shows you don't know anything to claim that.
Shadowlite
I suspect is due to the capacitor not installed / not installed correctly, which will cause those issues to appear. If not Tuya products are generally fine if you get from the correct OEM manufacturer.
katty91
capacitor is installed on the light side between live n neutral. even got in electrician.
might be quality issues as u mentioned since there are so many tuya switches in the market
LordDeathZ
I just bought Aqara smart curtain motors for my house but I was told that I need to get the gateway hub to run.
I was recommended Aqara M1S but told that there is only 7m range, and need to buy more to overlap the whole house.
Is there another solution?
Do I need to buy multiple gateway hubs?
What other gateways hubs I can consider other than Aqara M1S?
batniss
Yes, multiple. because it doesn't work with WIFI. A lot of people don't consider that end up spending even more. I came from Aqara before the switch to Tuya.
LordDeathZ
What Tuya gateway hub are you using? Can sic?
Can it work with China version Aqara products? (I bought the curtains motor from Taobao)
