TanKianW
Hi,
I have a mix of hardware, some given, some leftover from previous projects.
1. Aqara M2 Hub
2. Aqara D1/H1 switches
3. Aqara Cube, Motion Sensors
4. Smart Things
I plan to install Aqara A100 Smart Lock, but i plan to mix some Zigbee sensors, such as Smartul Smart PLug with metering, can those be detected under M2 hub? or should i get Tuya hub>?
I wish to control all the devices in a single app if possible
Can check out Home Assistant (HA) for all-in-one app integration and automation. Runs locally without the need of external cloud services (unless your integration requires).
vodka_water
Hi,
1. Aqara M2 Hub
4. Smart Things
Can i know where u getting yr aqara A100 from? Cos i found this seller from shopee but the installation fee is too much as compare to others.
https://shopee.sg/product/133942249/17316830396?smtt=0.796584-1651554773.9
katty91
katty91
Hi,
1. Aqara M2 Hub
4. Smart Things
don’t think u can add smartrul devices into aqara app
koohansen
Some of my existing wall switches is a 2-way switch. Will this have any issues if I replace them with the Aqara D1 switches?
TanKianW
bro, just one question
What do you use to sort out the icons in that grid rather than having to click up down just to fix in place
Choose "grid" under "By card", then custom how you want the vertical stack and horizontal stack to be on top of each other.
Check out this Youtuber Channel to improve your dashboard outlook.
You can also download his custom dashboard on github as your own.
hayashiryo
Hi. I am planning to get the Aqara 3 gang switch and SmartThings.
I understand Aqara doesn't work out of the box with SmartThings and requires DH installation.
Did any1 manage to install a DH to get the 3gang to work properly?
koohansen
hayashiryo
Hi. Thanks for the link. I reviewed Alex Teo's video before. But I think he used only the 1 gang and 2 gang. I read that Aqara 3gang seems to have problem linking to SmartThings.
So I want to ask if anyone managed to link Aqara 3 gang (wired) switches to SmartThings. Either D1 or T1 versions
koohansen
I will try that once my home reno is complete
hayashiryo
Is there any other recommendation for smart wired switches that works with SmartThings out of the box without DH? I need a smart switch that has 3gang
sundeath
I'm using mainly smart life compatible items - smart switches, door sensors, GU10 bulbs, (all are zigbee) etc.
However, i'm also getting Ikea smart blinds (zigbee). Should i get a tuya gateway hub or get an aeotec v3 hub?
Coz i'm not sure if the ikea blinds can connect to the tuya gateway hub. what should i do? please
Clwh80
you know any home assistant community locally?
TanKianW
Not of I know of. Though it is powerful and highly customizable. Maybe most find it intimidating here.
I have started using HA and contributed to the OSS project development when I was in the States (few years back). There are much more HA users and a stronger community there.​
Clwh80
arrr ok. wan to ask bond hub will be able to integrate somfy into HA?
ferbulous
Anyone modded your old wall/stand fan with this pcb to control with broadlink/remote?
Not sure how to get the swing working or need specific fan model, i can adjust speed/on/off just fine though
TanKianW
Mushroom themed Dashboard for Home Assistant (HA) smart home integration
Current smarthome Integration list:
  • Philips Hue (all lights)
  • pfsense firewall
  • Ruckus Unleashed (Access points)
  • TrueNAS storage (Plex servers & VMs)
  • Arlo CCTVs
  • Bond hub for RF ceiling fans/lights and Somfy curtains
  • Zigbee/Z-wave modules
  • Logitech Harmony remote
  • Haiku/Big-ass ceiling fans
  • Dyson fans and cloud
  • Ambiclimate/Sensibo A/C smart control
  • Google Home Display
  • Sonos speakers
  • Nvidia Shield
  • Deebot and Braava jet robo cleaners
  • Track every single home mobile devices
  • Track battery life/motion/light sensors of every remote controls/sensor
Adding custom configuration to count the "lights on", track the owners at home, custom greeting messages and active CCTVs:
Click into the individual custom room "button"
CCTVs integration:
Using your old ipad as a control dashboard at your tv console or even wall mount it.
You could use an intel M6 mini cube pc to run the HA operating system and supervisor, and attach zigbee/zwave module using the USB.
