TrueBeliever_jh
how much he charging you for extra point? Mine goes like 4 room for neutral wire ah? $8000! how stupid is that?
Pull neutral 8k~?
Maybe you can share the number of switches you are looking at~?
As well as the switch brand and model they proposed~
8k is only for the neutral wiring hor~? Coz some of the smart home packages are actually very expensive.
Raigar
Pull neutral 8k~?
They said to rewire the whole house to netural $8k (THIS IS EXCLUDING THE SMART HOME ITEM). That's why I find it kind of ridiculous. but without neutral wire, we still can use capacitor, but people are telling me that the capacitor doesn't last.
I don't have a brand but I will getting it from this shop https://www.smart-home.com.sg/wifi-products-light-switch
Alphas
Newer model of the non-neutral smart switches no longer require capacitor on the switch. There is even smart switches that do not even require live wire, since the switch uses kinetic energy to control a smart relay.
v1hypersg
can share which brand and which model and where to buy
Alphas
I will just simple requote again
There are also self-powered smart switches that do *not* require any wiring (not even live) to the switch. Basically it sent a RF signal to toggle a smart receiver as a switch. It also means the switch can be placed anywhere in the house, no cabling required. I did post it sometime back, some requires a small coin battery, while there are also kinetic switches that do not even require battery.
https://www.aliexpress.com/item/4001095272467.html?
No cabling, no battery, smart switch
https://www.aliexpress.com/item/1005002885325033.html?
TanKianW
https://homeauto.sg/smart-home/
https://www.moeshouse.com/collections/smart-light?page=2
https://near.sg/
anyone used any of the above services to buy their hardware and get them to install physically and configure for you ?
cant decide which one to choose
I am using near.sg heater switch. Did not get to engage their service since I installed and configure it on my own. I find the quality acceptable.​
XcoldstarX
Anyone here bought Aqara items from Taobao?
Any problems with usage in Singapore?
sequalancer
As @Alphas mention, you can get a 5050 WW/CW strip and a smart LED controller. A good one is GLEDOPTO, which I am currently using. You'll need to connect it to a LED driver (Transformer), which is connected to the mains. This means that you can connected it to a light switch to turn it on / off physically.
Hi, sorry for digging out your old post. I was considering to get yeelight pro commercial LED strip with yeelight pro bluetooth controller from a local retail shop but the cost is significantly more expensive and I came across your post recommending GLEDOPTO which i'm keen to explore. For now, i'm looking for option to purchase 2835 LED strip and driver from taobao and GLEDOPTO controller if it can be integrated into Alexa. But i was told that yeelight pro commercial led strip and and their pro S20 mesh gateway/eco system is quite stable and never go offline. so I'm torn with the ideas of integrating the smart led light strip to Alexa. I'm currently using Alexa in my home, with H1 switch and Aqara M2 hub. Look forward to your expertise advice. Thank you :)
deodorant
I haven’t yet but it seems that aqara things the major consideration is whether the item is China server version or intl server version, if you plan to use angmoh home automations (google home, apple HomeKit, etc).
Elon Jobs
I have been using non neutral eTouch switches for 4 years and counting (eTouch no longer around I think). A couple of ceiling fans and one LED light require capacitor. So far all good, touch wood.
Read HWZ Forum Rules!
Shadowlite
GLEDOPTO is mainly using Zigbee, which if you have a local zigbee hub (Like the Echo Show 10 and Echo Plus), it'll not go offline as they do not need to connect to a cloud server. For the Yeelight, it seems like they support local WiFi control from their description (not sure as I don't have it), so that would mean they likely won't be affected if the YeeLight cloud server goes offline.
I guess with your setup, if you don't have the newer Amazon Echos that has built-in zigbee, there might be an issue as unlikely the Aqara M2 will detect the GLEDOPTO.
That's one of the reasons why I went Home Assistant with Zigbee, less headaches on what is compatible with each other, and lesser number of hubs to support.
Alphas
Exactly, I preferred open source and wide compatibility on home automation devices. This way when a manufacturer decided to stop supporting their closed ecosystem for whatever reasons, you are stuck with devices that will be end-of-life and this sucks. GLEDOPTO controller can be added to Zigbee network and the gateway can be integrated with Alexa. Since Zigbee is a open protocol, there are wide range of HA devices that supports zigbee network and not limited to just one manufacturer.
adrwong
hello, can I check for those who are using TT Lock app whom have linked up to google home app, I had an issue when my locks in my google home app shows offline Yesterday so I try to delink and relink again but unfortunately I could not relink again as it shows “something went wrong, pls try again later” . This is under ScienerSmart when linking to google home. Anyone facing the same issues? Could it be the ScienerSmart Server issues? Previously I could link it with no issues.
Thanks!!
gLasKet
Hi! new to setting up smart home as well. Just wanna know if it is more ideal to get China Aqara M2 hub or the Global version one?
If i get the global version M2 hub, can i use it with the china D1 switch? Want to find the best cost effective solution as a starting point to set up smart home.
j4jersey.
Smart switch with neutral wire will not pass SP inspection if you decide to do a inspection.
water heater switches are two pole and disconnect both live and neutral at the same time so these definitely can pass SP inspection. But for normal light switches, they are just single pole and only the live wires are connected/disconnected when the switch is thrown. So if you have a neutral wire which is not connected to anywhere within the light switch housing I don't think it will pass SP inspection at all.
Do also note that in order to pass SP inspection, all electrical switches and sockets should have the Singapore Safety Mark as well. So if you have a smart switch which does not have safety mark then it will definitely not pass inspection.
is this true?
Occupy HK
Anyone know how to get the SP AMI Smart Meter electricity connsumption data into Home Assistant? I get the readings in my SP app. I would like to incorporate into Home Assistant.
funnycow
is this true?
where is this from?
