thretiredDad
When replacing a smart switch
do you switch off the circuit breaker?
If you do not know which One to push down?
thretiredDad
I treasure my life
So better to turn off the “main switch”?
mcbandrccb.ashx
The electrician who came my house
they just change and replace
justaman
Hi everyone, I am new to smart technology and still learning, may I know has anyone tried using Outsmart brand product? I am considering getting their smart switch but could not really find any review except their Shopee etc, thanks and Happy CNY! :)
Alphas
These are rebadged tuya devices, they all come from the same manufacturer. Outsmart seems to be a little more expensive than the same “tuya branded” devices so just get the one you need.
googoogaga
Hi I am considering automation for air-conditioners using temperature humidity sensors + IR blasters. Although I prefer Aqara, the smallest IR blasters and temperature humidity sensors that can run on small batteries I could find were from Tuya. I will combine these with starmex aircons. Does this solution make Sense or is there a better alternative?
ferbulous
That’s mostly how it’s done without getting sensibo or a new wifi enabled aircon
ferbulous
It seems like the battery is low(18%) . So I changed the battery but I think it's ONLY like 1.5 months. Is too too jiak dian?
When battery is low I can't even find the binary_sensor_motion on the entity list. normal?
BTW, is there a way to quickly re-pair the zigbee device under MQTT?
Is it force remove and repair?
Thanks
I mostly used aqara sensors and feels like their battery last forever
is it for your zigbee devices if accidentally unpaired?
ferbulous
The tuya smart circuit breaker like this is actually expensive. ~60 a piece.
https://a.aliexpress.com/_mNxcZ2wMy current place got ~15 of these. So am I looking at a $1k expense? More over these don't even have the power monitoring function that I need.
Alternatively this one below has power monitoring but needs to connect to the standard circuit breakers.
https://a.aliexpress.com/_mL7CicwIt's still $30 a piece. So if I need to real time monitor all of the circuits in my house I need 15 of these?
There’s also the one with ct clamps as a less intrusive method
googoogaga
Do you mean something like iotawatt?
This option does not have a easy to use interface. Hence my search led me to these din mounted smart meters that goes nearby circuit breakers.
ryouma
have anyone experienced buying Aqara D1 switches from Taobao China? Is it a good idea to buy a few spare switches just in case some arrives broken? Am planning to buy for the new house
justaman
Thanks so much for your reply!
katty91
can’t use other server.. means no google alexa and can’t use w global devices
laoahpeh
My electrician quote me $65 per point for neutral wire. Seems on the high side. Anyone know what's the going rate is?
hayashiryo
I bought Aqara D1 from Taobao. Realize they can't work with M2 Hub due to region lock. But I managed to pair it directly to my Smartthings Hub using Groovy custom DTH. However, the lag is often times noticeable. I am trying to figure out how to use Edge driver instead to pair D1 to my smartthings hub. So far no luck.
All in all, it's a little troublesome if you get China D1 switch. I think Aqara will soon rollout Matter for all it's products. So in the future, it might be easier to directly link D1 switches to Smartthings Hub.
hayashiryo
it’s quite easy, like installing drivers for your windows PC. There’s a bit of learning curve when dealing with device handler previously but with edge driver roll out, it’s simply selecting the right driver. So far I have tried D1, Wireless D1, mini switch and temp sensor with success. No luck with water leak sensor but not important.
Do u have the link on how to use Edge to link D1 switches directly to Smartthings hub?
