IloveEmma
- Nov 13, 2013
I've the exact same setup, Xiaomi GW, temperature sensor, Broadlink rm mini (if you don't need RF, use mini instead of pro). However I use Home Assistant to make them work together.
Another way is to go all Xiaomi products, buy Xiaomi IR blaster instead of Broadlink. You should use China server for better device support. I don't know how complicated are your automation but simple ones should be supported in MiHome app.
Wow thanks. I have some RF livolo lights and also ceiling fans which I want to control as well. Can HA make them work together? So basically HA = the hub?
I also have sonos / alexa (but i haven't activate yet). HA also can?
Thanks a lot..
