viix
Hi, is there any recommendations on smart switches with status feedback? My wife always cannot remember whether she switches off the storage heater after leaving house in the morning. Since the switch is to be used on the storage heater, it will be good that it can support a higher Amps current.
Thanks in advance.
U need a contactor between your smart switch and heater and also a hub to check the status of the switch.
See this post here for example.
You can also go the sonoff route with a wifi in-between switch but that is also troublesome as your main switch needs to be always on. But since it is for storage heater, I reckon you should just get a timer switch from choo chiang marketing with a contactor. it will turn off after the preset time.
Edwan@
experience with auto blinds
I am researching on automating the room blinds. Just 1 room. Saw brands like somfy , mysmartblinds but there are lack of support and thus can't understand fully or the way to start using it.
Anybody familar with it care to comment ? No need link up with other rooms or living room, just a room that is automated by itself and can have sun tracking and app functions will be good. Thanks
sHaDy69
I m in the same boat as u. Looking to install curtains n blind which can be automated accordingly
Any one has experiences?
SecretAgent
Anyone using those xiaomi mijia door sensor and wireless remote switches? These needs that mijia wireless gateway device in order to work?
LoneTraveller
Mijia gateway and AC Companion
Yes supposed to be 30-32 devices but I was able to keep adding to it. It doesn’t care too much about the smaller sensors but more picky on the number of wall switches
Hi, can i ask how do you find the aircon companion? Is it reliable as in is it able to take the load given by your aircon.
Asking as i just bought xiaomi gateway v2 and some zigbee plugs to try out.
Tia
jamie136
Smart Smoke detector
Anyone has install smart smoke detector at home? Any feedback and recommendation for new home?
Thnx :)
AsusEpoxy
Tia
The aircon companion is not really suitable for our environment as most of our local aircon power is outside connected to the compressor rather than inside the room. it is meant for those china style single unit aircon
pajamasguy
Tia
I did not connect to my aircon. Im using just the IR to control my AC
pajamasguy
Thnx :)
Using Xiaomi Honeywell smoke detectors. It can work on its own but better if connected to the mijia hub so that it can send you notifications
nogizaka46
You guys are noob, still need to buy so many machines to clean one f.uckin home.
I have Xiaomi maid to clean my house.
SecretAgent
Yah xm... forgot to mention... but i think only xm reported failure here lol
2 days back I'm I cn. Got that gateway from xiaomi shop! NB, quality sucks! Plug in to one of my multisocket and pull it out, the cover comes out broken!
Go back to the shop kpkp they don't want change! Get my lawyer(I'm srs here, I have my own China lawyer) call up their hotline they throw smokescreen here and there!
Pui! This kind of quality still dare IPO!
pajamasguy
Where did u mount it?
Guess what? I haven’t mounted them yet. Supposed to stick them onto the ceiling but I dunno if it will hold up. They also provide some screws and anchors but I don’t want that as it involves drilling holes
I might just place them above my cabinets or something but ceiling is best location
pajamasguy
One of my non-neutral double rocker declared uplorried...
Can it still turn on/off the lights by pressing the buttons? Both rockers dun work?
By any chance the lights you got the switch hook up to are also smart bulbs?
