Oh thanks! Forget that these are smart lights that I can set rules for.
The more i read the more confused I am.
I understand that xiaomi is now compatible with google assistant/Alexa. If i get the sensors, can i just set scenes on google home or must I still have a xiaomi gateway to control all my xiaomi stuff? Or alternatively can i just do it through the xiaomi app?
Correct me if I'm wrong, xiaomi gateway connects to devices wirelessly and does not need to be in the same room. So 1 is enough for the house unless I need to connect more devices than what they can support?
If my router is down (no connections at all, not only internet), all this smart stuff won't work right? Or cos xiaomi uses zigabee, it will all still work?
I am not 100% sure that this will work but it is easier to use light strip and wall switch from the same ecosystem e.g. Yeelight strip with Aqara wall switch. On my Android MiHome app on China server, I can add Yeelight strip. So I am assuming that you can add both Aqara wall switch and Yeelight strip using MiHome app and set rules to turn on Yeelight when wall switch is ON and vice versa.
