tecnica
Ok I setup Kyla liao.. for all those IR devices, I guess I can only turn on and off only with Google Assistant, cannot change fan speed, change tv volume etc..
For air con I use Google Assistant to set it to 23 degrees.. I wonder is it really so smart can set on my starmex or just turn on nia? If turn on only is it turn on at my last used setting?
Oh, I can’t get starhub set top box to work.. haiz..
boliao45
Maybe can email queries directly with aztech.
For ir controls working with my starhub cable set top box only via the app, gh can only on/off the set top which is basically useless as mine is always on by default
plustwo
kyla can set number for temperature or just +1 -1 until hit?
bluez
Hi guys, need some advice. I was building a xiaomi ecosystem, then my dad went for the Phillips sales tonight and was sold by the Phillips Hue stuff.
I understand the 2 ecosystem can co-exist in google home, but can I set scenes and set conditions cross diff systems? E.g. if xiaomi wireless wall switch is toggle, off all lights (including hue)?
Can I still use a xiaomi neutral wall switch with the hue lights? Will it go haywire?
earthtk
It won't but if you want to turn on the light you need to enable the xiaomi switch first before turning on hue lights.
bluez
Thanks! Was just afraid of overload or system conflict.
Realised some of the ceiling lights bought are not hue but remote control. Does it mean if i use a rm pro I can dim the lights too?
ihuazai2
they replied. They have to ship from china too.. so it's like ordering from aliexpress..
ihuazai2
Some questions for current motorised curtains owners.. :
1) What is the difference in the track used by Somfy motor vs Dooya / Xiaomi Aqara motors? Are the two motors able to use the same tracks? Am wondering if i can get local/malaysian vendors to install the tracks for me (they use Tube, Somfy or Nova motors only), while i get the motor separately.
2) How long did the DT-82 tracks take to arrive from china for those who ordered from aliexpress/taobao?
3) Any recommended seller for the DT-82 tracks?
4) Did u have to further cut the tracks to fit your installation?
5) Did u do motorised for both day and night curtains?
6) Any advise on what to take note of, either ordering from taobao or getting the somfy systems from curtain vendors?
(e.g. it seems price from somfy website direct is cheaper than those from curtain vendors
https://store.somfy.com.sg/productdetails.aspx?pid=595#
https://store.somfy.com.sg/productdetails.aspx?pid=596# )
bullfrog
While i never used Somfy before, i find them overpriced. I ordered my xiaomi motor and dooya curtain tracks online. As long there are no bends, just give the length u need and they will cut it exactly.
I assembled it on the floor. Just buy curtains from a local supplier here and ask them to help install the tracks for u. If its just drilling with no cutting or dissembling of the assembled track, they should accommodate you.
My next project does have bends with day and night curtains. Unfortunately, i ordered the wrong length for those (the bends make it more complex. I will need to measure accurately and cut the tracks. Haven't found the time yet though. Will update here if i am successful.
ihuazai2
which seller did u order from? would like to approach tried and tested seller :)
tecnica
can i check with yall, how do i get google assistant to run Kyla app ah?
cant seem to create custom command..
james_chew
Hi all
I have some noob questions on aqara and hubs, am buying the aqara switches. also planning to get the vaccum
1) with the new samsung home connect being sold, would you all recommend it over a smartthings hub?
2) are you all purchasing the UK smarthings hub?
3) has the experience been good with using smartthings to control the aqara switches? ie are the device handlers working well?
4) should i just get the aqara hub? But i understand it can only work with alexa and not Google home
5) between alexa and google home, what is the better path? alexa is not officially availabe in Singapore, but it appears to be incorporated in more things on the market
Really hoping for help from all the experienced brothers here. thanks v mcuh in advance!
