pajamasguy
- Sep 28, 2007
supposed to last 2 yearsfor those that used for a long time, how long does the battery last for aqara devices btw?
my devices only a year old so cant tell exactly
For my previous place, it was exposed wiring(HDB) . So i pulled out the furniture, opened the trunking and laid a neutral wire from my lighting point to its respective light switch. Did that for where i wanted intelligent switches.
My current home has buried wiring. The wires are running inside conduits in the wall. My electrician simply pushed the neutral wire from the lighting point to the light switch. He just kept pushing until it showed up at the switch point. It was astonishingly easier than my previous place.
I'm still thinking if i should get Z-stick ( zwave ) or
something that has ( zwave and zigbee )
In theory combo is better. However, from my experience, generic gateways are hardly used. Most of these devices have their own gateway. And its better to use them than a generic one. Otherwise, you will find that they can only function a fraction of their advertised abilities.
And if you plan on aqara switches, buy the xiaomi gateway instead of a generic zigbee device.
nola... not planning on aqara just to future proof. i already have all my switches layed,, as mentioned just changing the hub nia..
so for zwave, the aeotec stick is tried and tested and is the one to work very closely with HA ?
Seems to be. I have not personally tried it but information online says it works okay.
https://community.home-assistant.io/t/installing-the-z-wave-aeotec-usb-stick-in-hass-io/69289
Use IFTTT but your room may already be flooded by the time you get the message
ifttt.com/search/query/rain%20alert
Ya...still thinking got other ways
How about using a water leak sensor? If it rains, the collected water will trigger the alarm.
I've tried the aqara water leak sensor. Haa, but due to some shelter covering my windows, the sensor will only trigger when there's super duper heavy rain. The sensor needs certain minimum amount of water to trigger. Fyi, I've placed the sensor outside, below the window at a 45 degree angle.
Here's the original idea :
If water leak sensor detect rains & windows are open -> close window blinds to prevent rain from splashing in![]()
can share some tutorial for this kind of stuff? i want to do but i scared when fusing two device the voltage different and fry one sideThink can hack the xiaomi wireless switch to this
https://www.aliexpress.com/item/Rai...lgo_pvid=dea68f32-a82c-4988-85e4-beff72fc6647
