bullfrog
- Jan 1, 2000
Can recommend some products
How about you list out what you want to get instead? Theres plenty of examples for smart homes devices mentioned in the past few pages.
IR blaster, wall switches, door sensor, automated curtain, security camera and light bulbs.
I’ve tried lifx and Philips hue light bulbs so far but both are very dim even when on max brightness. Can someone recommend a better alternative.
My suggestions (based on the purchases of the majority in this thread) are:
IR blaster = broadlink RM pro
Wall switch = aqara switch with neutral wire
Door sensor = aqara door sensor
Automated curtain = aquara curtain motor + Dooya curtain track
Remember to purchase the xiaomi gateway for all the aqara devices.
Thank you for the info! Really appreciate it! Shall start sourcing tomorrow
For those who did their neutral wire. Did u guys pulled the neutral wire through the existing concealed routing (not sure if it's even possible) or just lay new trunking from the power point to the switch?
I was thinking of that too. By then, there is flood in the house already.
Anyone looking for Aqara double neutral switch, I got extra 15 pieces to let go. Bought too much
can share some tutorial for this kind of stuff? i want to do but i scared when fusing two device the voltage different and fry one side
Think can hack the xiaomi wireless switch to this
https://www.aliexpress.com/item/Rai...lgo_pvid=dea68f32-a82c-4988-85e4-beff72fc6647
Don't bother with these type of contact sensor. works for a while, and once u don't clean the contact sensor surface and it oxidise, heavy rain also won't trigger. I used it before..
The best sensor is the hydreon rg-11.. anyone wanna do a group buy? Optical sensor is the most accurate. Used in all the cars wiper sensors.
I got my pi from here. Dunno how useful are the heat sinks but i am using those too.
https://s.lazada.sg/s.c33h
does it take a long time to reach SG?
I used the data.gov.sg API into my automation with a door sensor on my window to tell me if it's close.
Problem with SG weather forecast is that sometimes light rain also warn and in the end never rain at all.
In the end, just everynight close the window..
Hi Senior Bros,
Anyone here can advise on the switch for Tank-type water heater, or how to automate the water heater? Cos been reading on some switches, including Sonoff/Tplink/etc.. and most stated either 13A/2.99Kw or 16A/3.5Kw.. But i believe tank water heater uses 20A?
Idea is to be able to on/off the water heater when away from home using mobile phone. Absolutely nothing to start off with, so if bros can also advise a proven setup, will be very grateful. Thanks!
Just a etouch 20A switch to replace your existing mechanical switch & a broadlink RM pro to control.Hi Senior Bros,
Idea is to be able to on/off the water heater when away from home using mobile phone. Absolutely nothing to start off with, so if bros can also advise a proven setup, will be very grateful. Thanks!![]()
You will need a contactor and position it between ur 13amp smart switch and heater. So basically the smart switch only turns on the contactor and the contactor turns on the heater. The design is such that the contactor deals with the load and not the switch.
You will have to speak to someone familiar on setting such an electrical wiring up. Maybe someone at sim lim tower can help?
Yah. Took them more than 2 weeks. Closer to 3. But i wasn't in a hurry.
Below 100 can settle
Sent from HUAWEI BLA-L29 using GAGT
stupid question... so i'd get the z-stick for zwave and can i later add on xiaomi gateway for zigbee?
