OnePlus 8/8 Pro!
hlaffix
Hi, does anyone knows the Singapore future 5G network band? Planning to buy an export set OP8 pro.
Kitaro9202
I try another type c to 3.5mm
No sound come out despite the top status bar show headphone logo
Guess have to try using type c earpiece liao
jesongaudan
Guys, are you using both face unlock & fingerprint at the same time? Is there impact in the battery?
Also, I miss notification led.
kryptonit3
I would pre-warn of 5G required sort of activation from OnePlus end, could be similar to a volte type of manual activation required, quite a number of people are complaining of this issue in official OnePlus forums.
hlaffix
Does it means that it dosen't matter if i buy the l.ocal set or export set as of now since there is no guarantee 5G gonna work if Oneplus dosen't activate it ? Thanks
kryptonit3
I would assume that will be a big question mark now, looking at the volte now I am not hopeful. if u r one intention is to use the phone for few years in view of 5G support.. take note before purchasing, unless you are like some of us buy and sell less than a few months
:s22:
nexusscion
Anyone using the OnePlus wireless warp charger? I managed to get hold of oppo 40w super VOOC and it looks good at almost 5800mAh during charging.
Using Super VOOC 40W wireless charger with the 65W oppo adaptor.
*Updated on the mA as I didn't realize I have set throttle speed hence I can't charge as fast.
Seems like this is a better buy compare to the OnePlus wireless warp charger as it is rated higher.
nexusscion
Taobao sets are hydrogen and needs flashing to oxygen?
China set run hydrogen OS and other region is oxygen OS. You can flash but I think you will lose your L1 iirc. Need ask those people who got the China set
