OnePlus 8/8 Pro!
Kitaro9202
Can anyone scan QR codes with the default OnePlus 8 Camera?
Even though i have enabled the “Smart Content Detection” option in the Camera app, i realized it is not detecting any QR codes
If u have Google len install can open the camera app at the bottom left of the scree there is one small icon u click it swap to Google lens
xavierica
Anyone tried using Singtel Dash on OP8 to take public transport? Does it have issues like G Pay?
I tried using singtel dash on bus. I was in the app and there was no response. No vibration or anything.
Setting in nfc was set to " except another payment app open"
Sent from OnePlus 8 Pro using GAGT
hanadulset
Reposting for convenience. You may either like my post so u can refer in future or copy paste to a word document
Guide to enable VoLTE
Disclaimer: Try it on your own risk, dont claim from me if your phone up lorry :s13:
Does VoLTE really works or the VoLTE icon is just for show only?
P R N D
Now OP8 $739 after 80 coupon.
Can buy?
China rom flash to global rom by Seller.
Sent from Mercedes-Benz E250 using GAGT
Chuapl54@gmail.com
Is there any problems using export set in Singapore? Because currently one plus 8 export set goes as Low as 700+ while local set is nearly 1000
RollingGoodTime
Getting a set this week.
Read that there's issue with Google pay. Has it been resolved? It's intermittent or totally can't use? And only for transport??
How about normal paywave payment in restaurants and merchant?
P R N D
So far i read, cannot use Phone directly on Google pay on Bus and Mrt.
kaiser_7
Me too. I'm using export Op8 china version with global rom. No issues for gpay.
Sent from OnePlus IN2020 using GAGT
nexusscion
There's no issue with gpay for restaurant and merchants. Only some bus can't seems to read the nfc properly. Not sure if the newer bus reader will work or not.
I am planning to let go my pop-up blue set reasonably you are keen.
