OnePlus 8/8 Pro!
igarashi
Works fine for me.
The combination is to first go to developer options and enable non-standard NFC Tag support. Also use Google Pay, not Google Pay Singapore. I deleted the latter.
Will try again after enable this option see if it work...
dappercivility
Anyone used both the oneplus 8 and oneplus 8 Pro and can compare? I currently have the 8 Pro but I prefer the non pro interstellar glow......... But worry later feel not so good......
rootz
Bro, would u be looking at the cover often? If not, stick to OP8P.
Personally, it's the hardware that matters to me, and not so much into the outlook.
But again, everyone has their own preference.
kryptonit3
interstellar glow is overrated, it only looks slick in photos it mostly has that pinkish tone under sunlight. stick with the pro unless what you want is the smaller form factor.
nexusscion
Actually i prefer the size of op8 but the screen wise makes a diff. I feel ip68 and wireless charging is important to me. If op8 have ip68 and wireless charging, I don't mind sacrifice the screen for it and ditch my op8 pro lol
Aikon
Works fine for me.
Just tried, can't work on the bus.
Used my faithful SD Note 10+ with GPay detected immediately.
dappercivility
Thanks for the replies to my question. I'm looking for a smaller form factor phone for day to day use. It seems the OP8 also not that small.
