OnePlus 8/8 Pro!
igarashi
messaged mister mobile before.. apparently they said no user complaints, maybe majority user don’t use their device for daily commute via gpay.
HAHA they sure say no user complaints though many have message / call and ask them.
I personally went their shop and ask 1 month ago, also give same default ans.
phiber
Seem like only UK and SG got such nfc transport issue based on the forum
i believe when you tie a card to GPay, the card number is tokenized to another one, the real card number is not presented for payment,
instead a card number tokenized by GPay is presented.
It works for normal payments as they accept any card number as long as it's a valid credit card number.
then the bank end will reconcile with GPay system to match their the tokenized CC number to the actual card tied with that number in GPay system.
For LTA transport app, the card number that is registered with LTA is expected to be presented.
But when you use GPay on the LTA reader, the card number presented by GPay is not the one you registered with LTA.
So maybe the bank needs to work with LTA to match the tokenized number.
https://support.google.com/pay/merchants/answer/6345242?hl=en
KeYoKe
https://support.google.com/pay/merch.../6345242?hl=en
Even if thats the case, it should happen to all oneplus phones right? It only happen on local set and not export set somemore of a same variant
kryptonit3
works on export.. not gpay support nor Lta problem. gone through the hard way, already checked with their support, bug is purely on oneplus end.
kryptonit3
Your one work out of the box bro? No issues thus far? Whats the success rate?
all is well no issue.. right out of the box on AA. success rate can’t comment haha at least gary’s op8 also an export..i guess also works? :s13: :s12:
phiber
Ah i see.. then it's very likely a firmware issue with OP!
I read from here their support is lacklustre, i guess you can't expect much when the service center is a handphone shop in City Plaza!
No budget for Singapore compared to the big boys like Vivo / Oppo.
Might as well get export set if local set no warranty.
leowweiqi
Export n local set different firmware?
There is a bug in the initial firmware of local set. Need clean install of firmware to get rid of the bug. If update via ota the bug is being bring over
Need do the adb clean install of firmware.
KeYoKe
Disclaimer: At your own risk.. obviously Mister Mobile doesnt recognise this issue. So can only DIY
athenodorus
any simple and safe way for this?
