OnePlus 8/8 Pro!
KeYoKe
Oh so I'm correct that the phones are really getting a lot more ex than last year, I thought i was imagining things.
And qualcomm is the culprit for inflating the price since they can monopolise the market with their best soc
:s22:
Thinking to change to op8pro coz of a better camera... Op7 cam is actually a lot worse than my previous s7e, like a C tier cam. Then s7e is a high B tier. Not sure if op8pro cam really can be A tier tho
:s22:
So far reviews of op8 pro camera seem good leh. U can consider. See YouTube on the photo sample lo
leowweiqi
I will hold on first. Since 8T will be coming less than 2mths. Likely will use 865+, super warp charge and imx689 main camera
WhiteAnt
That time I saw the op7 photos also pretty good but when I really use, it is not as per my expectation leh. When the hands shake a bit, the pic like blur alr :(
I've a friend who might be getting Op8pro so maybe I can borrow his phone for a while to play with the camera :o
So ex leh $1k and I've been changing phone like almost yearly haiz... So waste money
KeYoKe
:o
If phone functioning properly just use it lor unless u need a better camera . Else just hold for 8T then decide like what leowweiqi suggests
Since your friend has it, borrow it and test is the best.
Economy not good now. Just take things easy. Change phones yearly is ok la, we have bros here changing phone monthly or once every 2/3 months to have a feel of different phones :s13:
leowweiqi
Haha. Okay la. You use photos for competition? Should be okay de OnePlus 7. It the same camera as OnePlus nord, 7t and 8
Kitaro9202
Meanwhile I change phone after 2 years or the phone gonna spoil
WhiteAnt
He not yet buy, also thinking bc v ex >$1k
His is op6 if not wrong, or maybe op5t
True, maybe I shall not waste money on phones le... :(
Nx year maybe can get Op8pro fr 2nd hand instead at 600?
No, my friend commented why my photos so potato phone standard... :s22:
Venkatdommata
even if work, banking apps might not.. you could try and update us here :D
Hi, did anyone try updating and see if it fixes Gpay issue?
Planning to buy 8 pro. Heard that black export set (for which Oneplus official store gives 1 year warranty) works fine. But want green one :-|
For me Gpay issue is deal breaker. I don't care about camera. Display, performance and battery is all that matters to me.
leowweiqi
Just flash the full rom instead of ota fix the issue
leowweiqi
Install gcam lo.can install that
Amuroraysg
I update to Android 11 Gpay is disable lol then I flash back the downgrade ota using local update and too my suprise it work but when I check I am now ba rom not aa I guess I select the wrong rom but no matter as long as my Gpay works
Now tap in tap out smooth and fast..
leowweiqi
See told u so. This remove the bug in the initial software for local set. Smooth gpay no issue
Those with local set got such issue just do the full rom update
garychengjw
