OnePlus 8/8 Pro!
igarashi
FINALLY.... 1st time use GPay for transport successfully. After upgrade and downgrade.... Pray no issue after next OTA.
leowweiqi
But I am looking to buy local set for 1 year official warranty. So I want to know if this can be fixed in local set (either by flashing or OTA update).
No issue with local set as there is a person last few pages said his okay no issue.
KeYoKe
Mine local set seemed fix after upgrade and downgrade. But export set dont need go through this hassle though. Just another alternative for u
athenodorus
Yea my gpay (default non sg version) is working fine now. Tried 2 trips and scanned instantly.
Amuroraysg
New update rolled out.. i wonder it fix the issue with it (For AA)...
latest firmware is 10.5.13.. but mine is BA liao so its 10.5.12 for me...
Amuroraysg
ya payment still works just need to screen unlock instead. don't think have any options for this, I was on a chat with gpay support..they are looking into this, better not another bug on OnePlus end :s22: :s13:
Edit: played around with settings in ‘screen lock’ was using face unlock disable it or ‘power button instantly locks’ on/off test, either one helps on the lock screen unlock.
Your last comment hit me.. face unlock.. it was working friday and i stop working the day after i added face unlock.. but you say you remove face unlock still no good then i :s11::s11::s11:
kryptonit3
:s11:
:s11:
:s11:
yea i was playing around with face unlock the day before and forgot to disable it..disable solved my problem :s22:
Amuroraysg
as for now, mine back to square 1 again.. from seemless tapping in and out to must unlock to tap in and out then lastly.. tap liao no respond or error say this card not supported...
really rubbish... i am doing another round of upgrade downgrade see if it helps... please remind me... any export set don't have issue? and what rom must those export set be to work in singapore.. i don't want to have bunch of china app and ads on my phone like my last OPPO Reno ace gundam edition.
