OnePlus 8/8 Pro!
Amuroraysg
But for simplygo should be just wake screen is enough
Which is how I did it Friday taking trip 3 time tap in and out without unlocking my screen.. now it stop responding and only work when I unlock the phone, worse is on my last tap out old problem occurs again.. tap and show error.. and work after few tries.. home this is one off otherwise is back to square one
fortunecat
Looking to buy this phone few months later, hopefully all these will be resolved :(
athenodorus
Also dunno why, after I did my 2nd downgrading, I noticed the default hydrogen & oxygen icon packs are missing. Lol. Not sure what's going on with these weird observations.
athenodorus
From play store download
Ya I can do that. I'm just wondering why the downgrade will caused some files to be missing. This doesn't seems right. Tmr I'll try the gpay again. I hope I don't have to redo the wiping for the third time.
leowweiqi
Cos maybe previous it also background download from play store just that I dun know
kryptonit3
ya payment still works just need to screen unlock instead. don't think have any options for this, I was on a chat with gpay support..they are looking into this, better not another bug on OnePlus end :s22: :s13:
Edit: played around with settings in ‘screen lock’ was using face unlock disable it or ‘power button instantly locks’ on/off test, either one helps on the lock screen unlock.
Venkatdommata
Gpay is a deal breaker for me. So can I go ahead and buy now that you guys confirm that it can be fixed with flashing?
kryptonit3
But I am looking to buy local set for 1 year official warranty. So I want to know if this can be fixed in local set (either by flashing or OTA update).
this is not a confirm full fix for local set suggest either wait for 8t or wait till the next ota to see if those whom flashed to verify if the prob will return.. next ota around the corner according to op forum.
