OnePlus 8/8 Pro!
KeYoKe
I managed to get a bnib set for a good price in carousell.. yup.. curve less pronounced.. similar to the s20.. op8pro curve abit aggressive..
Ahhh icic... Im looking at 8t, but somehow... I still prefer the AG glacier green on 8 compared to 8t as 8t aquamarine green is glossy, and only lunar silver is AG
hellojeffo
Just sharing.. Circles got 5G at Orchard.. near cuppage area
Posted from PCWX using IN2023
ranmaru1987
Is fast charging and that extra 30hz refresh rate important to u? If not I believe the 8 has better form factor..
Pryson
Guys in case anyone needs it, after reading up google play services causing drain on android 11. I disabled google play store and services. Sot is almost doubled from 5 hrs to 10 hours for same usage.give it a try while google is fixing it.
Only if you have battery draining issues. Disregard if your phone is fine.
delrosa81
If Google play services is disabled means my apps won't be updated as usual? So far my battery life seems same pre and after update. Just curious about the battery drain issue you are facing. Maybe I try disabling the Google play services later.
Posted from PCWX using IN2020
delrosa81
SD S20U not as power efficient as the SD N20U for some reason. Noticed a fair bit of difference. Wonder why as hardware more or less the same.
Btw u not using note 20u already meh? I feel like getting a sd 20+ or u.. but v ex.. lol
Pryson
Yes, won't be updated and this is a nono for most of them. I am just testing things out because the battery drain and the SOT is too little.
I have experiment with the 2 same phones with different models;
- OnePlus 8 Pro Model IN2020
- OnePlus 8 Pro Model IN2023
Both are running on OP8Pro_02_BETA_2 Android 11.
activities include the following;
- YouTube videos
- Gmail
- 1 hour of Gaming, Genshin Impact (high gfx demand)
- Facebook, IG, WeChat, WhatsApp, Telegram, LINE.
Tried alternate days with 1 of the phone for same usage pattern.
Till battery died - Approx. 6 HRS 30 - 50 mins for both phones.
After i disabled the Google Play Services, i can reach Approx 9 Hours 30 mins SOT.
Not saying disabling google play services makes sense since we are using it daily. But that is what it is now till google fixes the issues they acknowledged from the oneplus forums ppl.
Not sure if that helps some ppl here, just sharing.
KeYoKe
- YouTube videos
- Gmail
Google is fixing it... Somehow there is this bug about the services draining batteries.. it is haunting p4a as well
