OnePlus 8/8 Pro!
eskimobster
Still buzzing rapidly🙁
I tried activating the non standard NFC tag toggle in developer options but find that it doesn't stick. When switch menu it revert back to off.
brx1987
Will be sending for reflashing at Mistermobile on Tuesday and see how.
I read at oneplus forum, seem to be affect smrt readers.
I paid for food using phone nfc, went thru immediately........
I m starting to suspect smrt n sbs readers nw
Kitaro9202
Hmm when I did factory reset I didn't wipe internal storage data. Wonder if that's the diff why my gpay doesn't work?
Not sure leh cos I do the normal factory reset I did not try to use gpay after that
and I try to restore my whatapp data but cannot after that full factory reset my whatapp data cannot be restore due to corrupted
So I try use gpay after I full wipe my data
karloil
I'm not using GPay but I frequently use EZ-Link.
Updated to Oxygen OS 11 (no factory reset) - and EZ-Link is now working!!! :s12:
rerear
Can update to the 10.15.12.IN21AA? Any problems with ezlink and gpay? Mine is India export set. I assume this is Oxygen OS 10 still? But somehow it just appeared, so not sure why I got 10 even though now 11 is rolling out.
rootz
Cause the updates should be increment. You get bits here and there.
ongkc66
Hey guys, just to share my experience here:
Phone model: OP8 Local Set
GPAY NOT working for MRT/Bus on Android 10
These are what i did as advised by the gurus in this thread and my GPAY is working fine now for MRT/BUS on Android 11:
1. Update to Android 11 through OTA
2. Perform factory reset (delete all data)
3. Wipe cache (refer to the steps here)
4. Disable default Google pay
5. Download GPAY Singapore
KeYoKe
Anyways guys, seems like volte hack is not working after android 11 ya. Just fyi for those whom activate it before
Posted from PCWX using Pixel 5 Sorta Sage
Kitaro9202
Any one camera got got problem?
Mine when I try to take a photo sometime the camera cannot auto focus
Pryson
Has anyone with stable build in android 11 from beta 2 experience better batt? On b2 but batt really cmi. Do hard reset system wipe and cache for 1 week no improvement.
houyin95
Guys, I updated to os11 ytd morning once I saw the notification when I woke up. But gpay for mrt still not working the flashing thing still happen. Then I got abit dulan and the thumb zam on the feedback or report button aft pass the mrt gantry with my card.Then magically it just work jn no idea why and how it happen, mine is local set from lazada not the China version
athenodorus
Just do a clean wipe..later issue come back again waste your time. Rather do it clean once a for all.
meowth82
My phone is China set and Gpay for bus and train was working fine on Android 10. But after I update to Android 11, can't tap into bus. Tried use Gpay Singapore still the same. Any idea?
