OnePlus 8/8 Pro!
gtggtg
Just sharing.. Circles got 5G at Orchard.. near cuppage area
Posted from PCWX using IN2023
I am using M1 on my one plus 8 pro. i set to preferred network type to 2g /3g/4g/5g and also signed up 5g add on with M1 but I cant seem to get connected to 5G at Raffles place and marina bay sands.
anyone got any suggestions on how to get connected to 5G?
thanks
Pryson
The phone will only quick charge/warp charge with the adaptor and cable provided by the phone set? I used a Huawei 40W supercharge adaptor, it's just normal charging for my OP8 Pro. Is this normal?
KeYoKe
The only third party charger and cable certified to dash charge op8 series is oppo vooc charger and cable. They uses the same technology with dash charging
Pryson
I see, thanks for sharing. Haha i tried using my Lenovo Charger 45W, it can charge rapidly too. But i believe it will hurt the battery or is that fine?
KeYoKe
Lenovo charger should be using PD though, it charges fast but not as fast as dash charging. Monitor see if your phone is warm during charging
Dash charging has special chips monitoring battery temps and adjusting the current to prevent any damage to the batteries.
kiryu86
my oneplus 8 pro keep prompting me to upgrade oxygen OS 11,
not gonna upgrade since it affects gpay, need to do factory reset? so troublesome, i got so much thing to back up.
crazyrobot
OP8p is compatible with oppo airvooc wireless charger. It can deliver 30w wireless charging.
Pryson
What version you guys on which is better ? Open Beta 2 or Stable OS 11?
For stable version which region you guys using? EU NA or IN?
Kitaro9202
Try using baseus quite fast 60w de
Aikon
Hi folks. Im in dilemma to buy OnePlus 8 pro or S20 FE.
Any advice?
You not scared to get a lemon S20FE? If not in a hurry, wait until they fix the S20 FE if you're really keen. I'll eventually get this.
The reason I sold off my oneplus 8 pro was the gpay issue. It's been fixed recently though.
Theboy09
Hey all, how’s the handling on the 8 pro in terms of the curved screen? Saw some reviews mentioning false touches due to the curved. Is it that bad?
I have always used flat ones only
KeYoKe
Hey all, how*********s the handling on the 8 pro in terms of the curved screen? Saw some reviews mentioning false touches due to the curved. Is it that bad?
Thats a con of curve screen, but curve screen looks bezeless and futuristic too
There is this much software can do for false touches. Are u using the phone naked or with case? If with case, chance of false touch is way way lower....
brx1987
Did factory reset but gpay on mrt not working. Keep buzzing continuously very quickly at gantry.
yes sia, keep buzzing when i try to tap to board the bus.
I know dont upgrade oxygen os 11 liow
U manage to get it working? or still buzzing?
