OnePlus 8/8 Pro!
KeYoKe
My phone is China set and Gpay for bus and train was working fine on Android 10. But after I update to Android 11, can't tap into bus. Tried use Gpay Singapore still the same. Any idea?
Do a clean wipe bro... Mention alot of times liao :s22:
Posted from PCWX using Pixel 5 Sorta Sage
igarashi
Just updated mine to 11 with the updater. Factory reset and wipe cache. Tested Gpay SG on Mrt and work. Pray it last.
delrosa81
Experienced something weird with the 8pro AC2020 India set. With regards to the sms.
Internet Banking OTP and other smses comes in with no issues. Recently a buyer from carousell smsed me but I did not receive anything. This happened mid last week. On Friday sold the 8pro and swapped my Sim into the pixel 5. Smses came beeping in like crazy once the pixel 5 has completed its boot up sequence.
Find it rather weird this happens. Usually if there are any issues, there won't be any smses coming in at all. But this time round, certain smses did not come in.
McKee14
Anyone using OnePlus 8T? How's the phone? Will OnePlus phones generally get hot after using for long? Heard its cooling technology not that great. Is this true?
Considering to get OP8T as my next phone.
rootz
What's your current phone so that we can make better sense of what to recommend.
Cause if you want 8T, then question will be, why not 8 or even 8 pro?
McKee14
I'm currently using Pixel 3XL. Considering 8T as I do not want to spend more than 1k for a phone (which I spent on Pixel back then). I'm considering Poco F2 Pro as well, but can't seem to decide between OnePlus and Poco
KeYoKe
I will take oneplus over xiaomi anytime...
Reason? Miui is just :s22:
KeYoKe
Sorry, maybe too little details. Saw this person selling op8 on carousell. Unsealed set. Some op7t selling same price as this op8
Posted from PCWX using SM-G975F
I think it might be refurbished sets. See if u are comfortable with it or not. Ask if there is any warranty...
ranmaru1987
I think so.. this seller should be jtbc.. and is pre-order..
Sent from OnePlus KB2000 using GAGT
