PC Speaker recommendation
kittyklysm
Suspended
@kittyklysm just now i added to my cart, strangely if i go back to the cart is still $282 though
is it worth to buy?
but i already got 3 pair of speakers already
:frown:
after chiu type in your card details ish show 327.
bai 1 put toilet. pang sai and play calming nature sounds for peaceful sai sessions.
MrBoxySquare
plus one for this.. i've used $2k speaker (KEF) and the $100+ R1280DBs....
dont waste money on expensive speakers LOL
KEF ones in the past
Is it much better with the edifier sub woofer?
zzzzzzz
Nice hoot... but I cannot have 2.1... really dunno where to put the woofer... a bit zhor dang...
Subwoofer difficult to mope floor
:frown:
what u using? why so many speakers?
Living room, computer room at own place and bedroom at parents place
R2000db, s2000mkiii, r1280db
:frown:
:/ chiu really hooting?
put on the floor lor. at night can use it to promote good neighbourly relations.
Still thinking. 282 worth it or not?
:frown:
wwenze
CONSTANCE THAM
1 out of 5 stars
Reviewed on 28 June, 2022
Did not find anything in product description of the 110V. Bought based on previous reply that “ it can be used in Singapura “ Unfortunately Singapore voltage is 220 V Attempted to post a question Re voltage but no reply prior to that. So item was of little use. Discarded as it was too much trouble to return item from Singapore .
Read less
zzzzzzz
CONSTANCE THAM
1 out of 5 stars
Read less
$282 is from another seller singha-store
:frown:
sTiCkY
:frown:
:frown:
:frown:
then u buy the klipsch for what?
replace the r2000?
zzzzzzz
replace the r2000?
not buying le, duno sg voltage can use or not
got no more space for another speakers and cannot affrod to buy it
r2000 under utilised listened to it maybe less than 20 times
:frown:
