8-lane
- Jan 29, 2013
Haha that one I know..Machim like Toyota and Lexus mah…
Yup. Actually no need to spend that much to build a reasonably competent hifi desktop setup. I think 1k-3k more than sufficient. Cannot buy big speakers anyway, can only stick to smaller bookshelves.Slightly off-topic.
Most of these high-end hi-fi audio equipment also use ready-made parts from other manufacturers.......after a while when you know the few quality OEM part makers in the market, you can save a lot instead of blindly pursuing the atas brands.
Dynaudio is one such manufacturer. Many years back some tweeters used by Sonus Faber are from them.
Scm7 is great for desktop use. Ok what, now only increase a bit to $1.6k. Might actually be cheaper coz they might give discount if you ask.i use atc scm7 for desktop,their driver and tweeter self made and closed box so ok for nearfield and before covid profiteering-inflation, was 1.5k++, local stock cheapest in world![]()
Sold byEdifier MR4 on sale $86 after click click on vouchers
https://www.lazada.sg/products/edif...dio-studio-home-i2417503033-s14252091218.html
That rating is just a consolidation of all sellers under Taobao, and doesn't give info on individual seller.
I think you go Adelphi walk walk and find will be easier.Wanna ask the pros here
I bought Klipsch Heritage Promedia 2.1 and will be getting the set delivered tomorrow.
Read up a bit and found a lot of people complaining about the default given rca cable in the box is trash and causing hissing and sound quality problem.
Can give recommendation which brand and type and where to buy a high quality RCA cable. Best is places like challenger or harvey norman or best denki kind of places for convenience. But not sure which brand and type to buy to be considered as high quality for the sub.
Sian lah if like thatThe problem isn't the cable, it's the speaker design.
this or creative T60@S$99 ?Edifier MR4 $76, it has more reviews since I last posted this seller
https://s.lazada.sg/s.bGqyA
I have no experience with T60, the only creative speakers in their recent line up I have tried with a PC are pebble plus, pebble V3, stage V2 and none of them are better than their T40.this or creative T60@S$99 ?
