POCO X3
Nakedtoes
yes both are 6.67 inches screen size. the only concern is the position of the front camera cut out. for my case no issue, camera cut out just nice. if you scare, get the SP w/o the camera cut out but probably you might suffer some quality in the photo for selfie. a lens see through a tempered glass and matt surface is not the same.
I been using k30 pro monqiqi glass on note 9s same 6.67inch screen. No front camera cut out.. But is good cause dust will accumulate inside the cut out.
ahfish22
Don't understand your question. Phone has NFC and can support Google Pay, there is no Xiaomi Pay, Wechat works with QR code.
Edit: Received this case, camera bump is covered up, case height is slightly higher on the front screen However, the sides are quite thick. For $3.60, really no brainer.
https://shopee.sg/product/233713865/5356026441
90b672c4083cc47e821afbc56bf9b9b3
Looks good on photo. Tempted to try this casing.
Compared with the nilkin casing. The nilkin screen edges not very well protected.
And the rear that holds the sliding camera cover is very tall. Not that fantastic.
Made my already bad nfc reception worse.
newcell
Display text size.
Some apk text not displaying full when select one step higher than small.
rathalos
Indo sets gets 8GB of ram.
While ours get only 6GB ram.
Why do u need 8gb? And more ram = battery drain because ram needs a charge to maintain it's volatile contents regardless of whether it is all utilized or not..
SPEED
Just feel the more the merrier. Plus it's like same price you paying. Cheers
EveMuffins
I read it's soft plastic..bendable silicon like the free Xiaomi casing right?
Is the camera bump height taller (more protection) than the xiaomi casing?
In general, this case or xiaomi case provide better overall protection?
rathalos
India one has no NFC.. u get more ram, but lose NFC.. more the merrier, but u won't even get to use all of it.. at peak, I only use 4+gb out of 6.. 1+gb paid for and wasted.. why pay extra for things u will never use?
twosix
u dun use all the ram does not mean others will not. those who play games or have many apps open will use more ram naturally.
human_shieldz
Don't underestimate the power of bloat from Xiaomi. If i don't reboot my other Xiaomi phone, after some time, out of 6GB only about 1.8GB free even if i'm not doing anything. If i run some intensive apps, can go below 1GB and i think it's always good to have at least 1GB free out of that 6GB else phone will be quite laggy.
justln
The silicon case camera bump is around 2mm higher than the camera, yeah soft silicon. Prefer this cause it covers camera as well.
But Indon one supposedly has 8gb + NFC. :s13:
eip1234
RAM works differently from "Storage". Whatever and no matter how much RAM you have in your system, the OS would first of all utilize them all, in full, as a container for background data such as processes, apps, temp data, etc etc ... After it's "full", when new space is required, old data will be "erased" to make room for the new space requirement ... Henceforth bigger RAM does consume more battery power ...
Having said that, bigger RAM has more spaces for data so it reduces erases, overwrites, closing of background apps, processes, etc so it saves battery in that sense and renders the device "faster" and "smoother" ...
Therefore, overall, bigger RAM advantages do seem to outweigh the disadvantages ...
human_shieldz
You are right but It's hard to quantify how much power is used in real life if there are more RAM vs not having enough RAM and there are too much writing to it but having less RAM is definitely frustrating in real life usage with lag and apps crashing. If you ask me and i think everyone else, no one will say less RAM is better :s13:
Maybe Apple users
eip1234
Yes, you are right too as I was addressing some people's belief that "I don't need so much RAM" ... In general, when all things being equal, more RAM is more beneficial ...
