POCO X3
FlameTakuya
Anybody else feels like the phone takes too long to load up file browser, photo album browsers etc? I have a fast microsd card but I think it could be that the phone is taking too long to load it still.....
EveMuffins
The charger that comes with the poco x3, if I unplug that cable and connect it to power bank or Note 4 charger head to charge the poco X3, will it work?
FlameTakuya
The charger that comes with the hp, if I unplug that cable and connect it to power bank or Note 4 charger head to charge the poco X3, will it work?
Will work but charge speed depends on how fast/what level quick charge your plug can support.
Absolute fastest is the plug and cable that both came with the phone
twosix
It's the 732G chip that is slow in processing the photos. Even saving to the internal storage, when one tries to view the photo immediately after taking, one will see the photo only after a second or 2.
This is the same on the pixel 4a.
rathalos
U using the stock xiaomi apps? Likely slow is cos they fingerprinting ur data to phone home la.. I dun face extra slow issues with other apps..
EveMuffins
Tks..so it's basically slower charging speed if I use power bank or note 4 plug which don't support fast charging.
Coz I dropped the poco X3 charger on the floor then now one of the pins is slanted. :(
Then I don't have type c cable so I can only use the cable that come with X3 and use other plug/power bank.
My note 4 cable is mini usb so I need insert the X3 type c cable into the note 4 plug.
twosix
The cable will work with any usb-a charger. It is also thicker than most cables to accommodate the higher current.
xenocide
someone asked about the casing i bought from Shopee recently.
i've received them both and here is a short comment review.
1st one: https://shopee.sg/product/164684915/4732139786
This a silicon case like the original but of thinner and lighter material.
wraps the phone nicely and added protection on the camera bump.
Being silicon, it has the same problem of attracting lint and dirt in pockets and has the tendency to stick to pocket when pull out.
2nd one: https://shopee.sg/product/178129848/4652494956
I like this alot! this is similar to the one i got for my Note10 and iPhoneSE.
its very popular these days. the back is hard plastic and has a cloudy finish.
The sides are also harder than usual silicon cases. the grip is good but the back can be slippery. the only minus point is that the camera module is exposed. No protection at all if you are the sort that put the phone camera side down. no problems with pockets as its smooth surface doesn't stick to pockets.
for the price, i'd say they are good and they are much lighter and slimmer than the original case. Charging port has no flap to cover like the original but i hate the charging port cover on the original.
Both are still going at 1.99 at Shopee now.
newcell
Anyone know how many fingerprint apk can we activate for this phone. I had one of my apk kickout from fingerprint. Terrible thing is too rely on fprint, forgotten my password.
Note: it did show a message briefly during kickout. But too late to stop it before it kickout the apk. Already spend 3 days trying to recall my pw, and still trying.
My previous phone, Samsung do not have such issue.
wongminmin
missed this :(
twosix
what is finger apk? cheem...
FlameTakuya
No I'm using quick pic and solid explorer (paid version) respectively, if anyone has better suggestions for gallery apps please let me know lolol
human_shieldz
The kick out thing, you mean it's like the app is freshly installed like you haven't done any setup before right? I think it has something to do with not touching that app for a few days and the battery saving system will automatically put it to sleep so i think it will wipe out all data along with it. My Samsung phone does it to and all i had to do is put the app under never sleep though this way it will drain your battery and also ram.
newcell
No, I used every other day.
I was caught by surprise that the phone just kickout from fprint to password. Without warning.
