POCO X3
Letyon
https://imgur.com/a/LASZgmm
Focus on the neck of the reptile
if you are on desktop, you need to zoom it with a mouse click
if you are on mobile, it will display in low res. so maybe cant see much difference.
I do not understand why Note 8 pro has a sharper look
They have the same screen.
Poco x3 Display IPS LCD
6.67" DotDisplay
Resolution: 2400 x 1080 FHD+
20:9 aspect ratio, 395ppi
Contrast: 1500:1 (typ)
TÜV Rheinland Low Blue Light certification
120Hz refresh rate
240Hz touch sampling rate
Corning® Gorilla® Glass 5
Note 8 Pro Display IPS LCD
6.53" Dot Drop Full Screen Display
Resolution: 2340 x 1080 FHD+
Contrast: 1500:1 (typ) | NTSC: 84% (typ)
Brightness: 500nit (typ) / 420nit (min)
Standard mode | Sunshine mode | Night mode | Color temperature adjustment |
256 ranks adjustable Reading mode certified by TÜV Rheinland
Anti-oil and anti-fingerprint protective coating
Supports HDR display
Specs taken from official website
Is there something wrong with my poco x3 ?
are yours ok ?
the screenshot i took from high res video from youtube
download and play on both note 8 pro and poco x3
friedmilo
Hello all, I've been using the X3 for the past 1 month or so, paired with a Samsung Galaxy Watch Active 2. Strangely the watch gets no notification at the start of each day even when connected to the phone.
Anyone here facing the same issue with your bluetooth wearables?
xenocide
i also have issues with Galaxy Buds with X3
while it says PAIRED and Wearables app shows connected also, i get very choppy audio that keeps dropping. its like continuous stuttering. damn irritating. in the end i bought a Haylou GT1 Pro and never had any issues thus far
justln
Discover this Poco x3 nfc doesn't came with wire earpiece.
Package contents POCO X3 | Power adapter | USB Type-C cable | Simple protective cover | SIM eject tool | User guide | Warranty card
:s22:
newcell
:s22:
Yes, same. Today wanted to listen radio. Open box, no wire earpiece.
Felt cheated.
fazer6s
Felt cheated.
Even the new IP12 $1600 dont include earpiece.
Even if X3 include earpiece I guess you'll say its not high end type with inferior sound quality.
True what some members state that buying a sub $300 hp but EXPECT a sub $1500 stats and accessories.
twisti
I have no problems with Samsung Galaxy Watch Active 2 on Poco X3. Able to receive all notifications. What I did is to lock the Galaxy Wearables app. Then set the Galaxy Wearables, Samsung Accessory Service and Watch Active2 Plugin to autostart and disable battery optimization for these apps.
newcell
It has a radio function, wire earpiece act as an antenna, so ideally should be included. Doesn't matter if its a cheap accessory.
For IP, their culture is to rape their customers. And many.
tanchoo1
Perhaps you should have found that out first before coming here and complaining, showing us that you didn't do proper research before buying the phone?
kazuki666
Actually curious about the radio function. If we are talking about local radio stations, there is an app for it which also work with wireless earphones right?
Sent from Xiaomi POCOPHONE F1 using GAGT
twosix
fm radio needs the wired earpiece to act as antenna to receive the signal. wireless earpiece no wire, so no antenna.
i tried the fm radio. can play to the speakers, SQ quite good. now i can listen to radio outside the car. haha...
