POCO X3
newcell
Anyway, just to warn incase it happens.
Please save a copy of pw if using fprint for login.
rathalos
No, I used every other day.
I was caught by surprise that the phone just kickout from fprint to password. Without warning.
Never had that issue when using google pay that is secured with fingerprint.. did u update the app?
human_shieldz
If it's happening to this phone and not Samsung phone and also not other apps on this phone then it's likely the app problem on this phone has bug and it might happen again until there's an update.
twosix
I have no problem with fingerprint lock not working with my Samsung phone and this fone. All apps working with fingerprint login.
newcell
Thanks, apk was "Enpass Password Manager, latest update 11Sept2020".
Didn't expect to happened on this apk.
I use often, having it for about 2yrs.
human_shieldz
Thanks, apk was "Enpass Password Manager, last update 11Sept2020".
Mystery of the world haha. Did you happen to change or add new fingerprints after configuring the app?
newcell
Ah... yes, did add another fprint.
So, possibly that could have caused it.
Thanks. But never encountered such with samsung phone. That's why I suspected issue could be from phone. Least to expect such issue to happen, cause once an apk had fprint activated, it should stay, even with additional print added. Anyway, something new to me.
Luxanna
Poco X3 Case and Screen Protector
Anyone knows if I can use a full coverage tempered glass along with a case? Poco X3 bezels seems tiny scared the case will push it. I am going to use the IMAK Airbag Shock Resistant case.
human_shieldz
It does for Samsung phone too. I'm currently using a Samsung phone as well and after sometimes when i find that my fingerprint login isn't sensitive anymore, i'll removed them and re-add in again and that will cause some apps to prompt me to setup fingerprints login again, especially the Bank app.
Maybe, just maybe, it's up to the developer to make it this way for security sake so that's why only this app you encounter. Too many possibilities but just know that it does and it's a good thing actually cos someone might have access to your phone after you login then somehow know your password and add his/her fingerprint in it then can access your phone without your knowledge but at least the Bank did their job by treating it as a security compromise and disable it.
twosix
if u add fingers, apps will not ask to register the fingers. but if u remove a finger, then apps will ask to register the fingers. quite a standard practice imo.
newcell
Yes, agree. Couldn't recall but think may be due to finger removed. But than other app was OK, no issue at all. Only that particular one. Haiz... Have to redo many many passwords. 😭
FlameTakuya
Mine suddenly stop, but I off n on NFC and it works again..
It's kind of in a weird position. I can still pay for things like bus etc and it can read my amiibos (lol)
Specifically the orange juice machine cannot read. Hahahah. Then I think is orange juice machine problem liao. Dunno why not compatible.....
rathalos
Maybe cos orange juice machine use wire card as the payment vendor? That's why cannot liao?
FlameTakuya
Is that the reason? Idk. I was using it just fine around 2 weeks ago and before. Did they change something? Huh.
Letyon
Hmm.. just bought poco x3
do you all feel that the poco x3 screen is abit grainy and yellowish ?
I download a video and took screenshot with another phone
please see the comparision between Poco x3 and note 8 pro
https://imgur.com/a/LASZgmm
Is there some settings i need to tweak ?
Thank you
