POCO X3
justln
Just changed from default silicon case to this. Cheap and good, black silicon with smooth matte finish that's very nice to touch, have ring and metal button for magnet holders. Case fully covers camera with 5 holes for the lenses and light.
Metal ring always break de. I always buy default silicon case then another phone ring.
kottty
this one wouldn't..been using this type case for all my previous phone .very solid...
Sent from POCO X3 using GAGT
sky00sky
Sorry seems abit random to ask here.
I just got a X3 on 11.11 for a family member to replace his old xiaomi phone which is dying soon.
So how/which is the most direct way to transfer everything from the old phone over to the new phone , including those apps and stuff.
I googled abit i see the Mi MOver was wondering if this is the best.
I using apple so not too sure what is the best way for xiaomi hence this questions.
Thank You.
justln
I have the exact same design with no ring, just add a flexible fabric handphone ring better for me. Last time buy cases with ring attached all break and can't use.:s13:
oddbasket
I'm still using the original SP. which SP to recommend?
I just changed from default sp to Nilkin Amazing H tempered glass, easy to apply and no gaps on the side, can push out air bubbles. Covers the whole usable screen nicely and has oleophobic coating. Doesn't have hole for front camera, so the glass goes over it.
EveMuffins
if I'm someone who likes to change casing every alternate days, will removing and putting on the casing sort of lift the screen protector up?
oddbasket
There is a 2mm gap between the tempered glass and the edge of glass screen/cases so they don't touch when you remove case.
SPEED
Can share the link where you got it from? Thanks
ZrE0_Cha0s
Thank You.
mi mover is the only xiaomi app to ease the transfer, but cant do it for apps, but u can dowload it from play store.
Angtehkor
Now this phone move very slow. Think now here bros and sisters slow down in posting
kottty
anyone tio yellow tint bug?yr phone screen will suddenly become yellowish. happened when using chrome ..need to toggle reading mode on off become normal back..
twosix
i think it happened to me last night when using Brave browser. thought the night mode turned on.
kottty
found the solution at xda for those how using chrome got this bug..
For those who have problem with yellow screen in Chrome, try disabling #dynamic-color-gamut in Chrome... chrome://flags and search #dynamic-color-gamut
oddbasket
My set bought from 9.9 so far nv experienced this, but sometimes when scrolling in chrome, chrome will freeze, tap home and then go back to chrome again then working again.
EveMuffins
for me not only chrome, play game halfway also.
